TB-02 gearing
Old 05-08-2006, 03:58 AM
Default TB-02 gearing
What are the gear ratios avalible for a tamiya TB-02.
And if i need to get hop up to use these ratios what are they.
abcd123 is offline
Old 05-08-2006, 04:15 AM
61T Spur use 16T up to 19T pinion. 58T Spur use 19T up to 22T pinion. 55T Spur use 22T up to 25T pinion. If you use Tamiya Super Stock motor use 24T going down to 16T pinion. If you use the Tamiya Sport tuned motor or just the 540-type, use 25T pinion.
I hope this helps....
macgyver1432000 is offline
Old 05-08-2006, 11:43 AM
Hebiki's Avatar
Trader Rating: 26 (100%+)
enjoy!
http://www.kawadamodel.co.jp/partsli...0.6module.html
Hebiki is offline
Old 05-10-2006, 06:00 PM
ford_racing's Avatar
There you go
ford_racing is offline
