best dyno for motor
there are various so called dyno's, but there more of motor break in machines.. indi, much more ect...
For all out dyno's the best two are prolly Competition Electronics Turbo Dyno. or the Fantom..
The Ce is very pricey.. and hard to find.. prolly lookin at 800+ used..
the fantom can be purchased at any time.. around 400 or so but you need a laptop for it..
there both good dyno's// some guys prefer one or the other for certain number readings..
Originally Posted by Guo Chean
i not looking the motor break in device.
hi dodo, how do you determine that it produce torque or rpm? i had Peak performance
Originally Posted by dodo
Muchmore motor master is not only a motor break in device, for me, it helps to determine the general performance of each motor, whether the motor produce more torque or rpm. Well at least that's enough for me at the moment.
How do you determine torque by using MMR motor master? does they show you the reading of the torque? is that any hidden menu becasue i cant find any reading to torque? thanks
Originally Posted by XrayFK
It doesn't tell you much at all, basically just tells you RPM and amps, at no load, so it's a pretty useless number. A "real" dyno would be either the CE or Robitronics. Of course the true test for any motor is actualy track performance.
hmm never heard of anybody dyno-ing mod motors.
19T's maybe, but nothing hotter.
I was always a big dyno fan, but I came to the conclusion to work on your chassis. 99 times out of 100 you wont get beat by a better motor.
But 99 times of out 100 you will get beat by a better working chassis.
may i know what is the basic requirement of the power supply if i going to run Fantom dyno system for 7 turn or lower modified
I always used a lead acid battery (in the manual it says with at least sumthing aH, don't remember now, I used around 30aH) to test motors.
