best dyno for motor >
best dyno for motor
best dyno for motor
Old 05-10-2006, 03:33 PM
  #16
Guo Chean's Avatar
Originally Posted by D_o_S
I've used the Robitronic, and its great, so I would reccomend that to you... unlike the Turbo dyno, it is not dependant on the slave motor...
I always used a lead acid battery (in the manual it says with at least sumthing aH, don't remember now, I used around 30aH) to test motors.
so min 30 amp is the best? or higher? thanks
Guo Chean is offline
Old 05-10-2006, 03:34 PM
  #17
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
Originally Posted by Guo Chean
i know the best dyno is on the track but if i have 50 piece of motor do you think i so crazy bring all motor goto track and test run every motor?
I have the Competition Electronics Turbo 45
Marcos.J is offline
Old 05-10-2006, 03:37 PM
  #18
Guo Chean's Avatar
so how many amps power supply that you used for you dyno?
Old 05-10-2006, 03:40 PM
  #19
Super Moderator
Marcos.J's Avatar
75 amp
Marcos.J is offline
Old 05-10-2006, 03:43 PM
  #20
Guo Chean's Avatar
75 amp
is there 30 amp enough used?
Old 05-10-2006, 03:47 PM
  #21
Super Moderator
Marcos.J's Avatar
for what dyno? for the turbo45 I wouldnt use anything less than 45 amps, what dyno are you reffering to?
Marcos.J is offline
Old 05-10-2006, 03:48 PM
  #22
Guo Chean's Avatar
Fantom dyno fact
Old 05-10-2006, 03:52 PM
  #23
Super Moderator
Marcos.J's Avatar
Fantom dyno fact
oh , Ive heard that dyno favors the motor with the highest rpm to be the best, I never used one but a friend of mine does have one and he tells me that he uses it mainly as a paper weight on his desk, but like I said I never owned one or used one.
Marcos.J is offline
Old 05-10-2006, 03:56 PM
  #24
Guo Chean's Avatar
thanks
Old 05-10-2006, 04:24 PM
  #25
Trader Rating: 17 (100%+)
i was thingking of getting dyno before, whats the minimum amp requirement for dyno fact??? thanks
EngTat is offline
Old 05-10-2006, 04:39 PM
  #26
BigDaddyT's Avatar
Depends what motor you're testing - the power source for the Fantom is used to spin up the motor with a flywheel attached, so there is a pretty high draw right as the motor starts to spin up.
I usually run mine from a 12v gel cel or power pack and they keep up just fine, but you could could probably get away with a 50A power supply.
I also run a CE TurboDyno in my shop - I find that it's superior for hands-on motor tuning. You can generate nice looking graphs with flywheel dyno's which is why I keep the Fantom around - I use it to generate the final data plot that goes in my packaging.
BigDaddyT is offline
Old 05-17-2006, 10:31 PM
  #27
any one have the spec for dynofact? can it handle up to 7t???
EngTat is offline
Old 05-25-2006, 04:55 PM
  #28
danjoy25's Avatar
Trader Rating: 38 (100%+)
How much would a Robitronic Pro Master in excellent condition be worth now? Its mainly going to be used tuning stock and maybe 19 turns. I know CE 45 is the best but I like the look of them and can also backup as a charger.
danjoy25 is offline
Old 05-26-2006, 02:58 AM
  #29
any one have the spec of dynofact2?
EngTat is offline
Old 05-26-2006, 06:38 PM
  #30
I think people go to crazy on using dyno's either the robtronic,fantom,or turbo dyno are great when they used correctly.Which is basicly to give you an Idea of what the motor is doing...does the fantom dyno like heavy springs not really some motors can fool it yes but after working with a turbo this is also true for that one the turbo dyno tends to like light springs on some motors.As far as I know we used to dyno 7t on the fantom it worked fine sadly I got rid of all my dyno's and am now looking for another one.Just remember no mater what dyno you pick you still won't be able to do all your tuning on it no matter what anyone says.
bill941 is offline
