-   -   XRay X8 (https://www.rctech.net/forum/electric-road/1128971-xray-x8.html)
danthrc 11-23-2024 06:38 AM
XRay X8
https://cimg3.ibsrv.net/gimg/www.rct...c39ec042f.jpeg
Lets get some conversation going about the new XRay X8 Pan Car
hunterdawg 11-23-2024 07:51 AM
Mine is sitting in it's box waiting for spring. Just need a servo, body and tires.
danthrc 11-23-2024 05:10 PM
Mine is in the mail and everything I need for it should be here by next Friday. I’m pretty excited about the car.
PEASNQUES 11-24-2024 03:40 PM
X8
Does this pan car have avy suspension at all? I was looking at a Serpent Taipan and it appears to have front suspension.
92mnstanger 11-24-2024 04:42 PM
It's all in the chassis flex. There aren't any conventional springs or dampers. I bought one and put it together a little while ago. I am not totally sure what I am going to do with the car up here as we don't have any good asphalt tracks in MN.
92mnstanger 11-24-2024 04:46 PM
https://cimg3.ibsrv.net/gimg/www.rct...242c0aa807.jpg
https://cimg4.ibsrv.net/gimg/www.rct...2ad0e799ce.jpg
danthrc 11-24-2024 06:15 PM
I was wondering about this myself. I’m sure some thought has went into the design, they usually do things pretty well.
danthrc 11-24-2024 06:33 PM
I also looked at that. The Taipan has pivoting upper arms but looks the same on the bottom like the X8. A solid bar. Neither have springs.
PEASNQUES 11-25-2024 08:18 AM
Chassis Flex
I am good with that. As long as I can get about 8mm ride height with trued foams I should be good at our mildly bumpy circuit.
PEASNQUES 11-25-2024 08:21 AM
After market or factory parts to tune flex? Or a dremel?! 🤣
danthrc 12-23-2024 04:54 PM
Well I finally got mine put together and out on the track yesterday. Great little car in my opinion. Probably the simplest pan car I have ever seen. I was a bit skeptical of the "non moving suspension" but the oring pivot and chassis pivot points seem to work well because the car drove outstanding. Fast, edgy, and consistent. You do have to be a little more conservative on the front end settings like camber and toe since there is no suspension to travel but you are tuning it to how much flex you dial in. Mine worked right out of the gate.
