Caster and Camber Flex
Does anyone know the technical reason why caster flex will add more steering? I know it does but cannot figure out why. The same question for camber flex. Thanks.
Oleg Alloy chassis for A800X was not available to this race and Viljami used our old C01B-AL lower deck. Note C27X top deck that provides an increased side flex of the front bulkheads and hence an increased caster and camber flex of front suspension. Due to an increased angle between top links the AM19-4 provides less flex of caster and it seems good for rear suspension but not for front (especially on asphalt) as lack of front caster flex reduces the steering that all drivers usually want to find on asphalt tracks. |
Flex creates grip because it is effectively adding an undamped "spring" to the chassis. More flex is the same as going softer on your settings, or softer on materials, hence more steering
To actually claim you are isolating the flex in caster alone seems a bit optimistic. |
Originally Posted by sosidge
(Post 16143273)
Originally Posted by rccartips
(Post 16143164)
Thank you Oleg.
Is this similar to having more camber gain via upper link angle (less bulkhead spacer, more knuckle spacer)? If similar why rely on one over the other for more steering? |
(Post 16143586)
Thank you Oleg.
| All times are GMT -7. It is currently 09:42 AM. |
