Old 10-28-2001, 09:58 AM   #16
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Originally posted by mailboxck
hey i have a tip 4 you guys...
to check if your shocks and chassis is balanced, place your car on the edge of a table...then with a screwdriver, try to lift one end of the car with it. Place the screwdriver dead center of the car and see if the two sides (left and right) of the car lifts at the same time...
Yeah, using a setup board works best. First settle the suspension, then place your srewdriver/allen wrench dead center. Use the edge of the setup board as a lever, and gently lift hte chassis up. Next, slowly lower is back down. If both tires touch at the same side, your tweak is fine. But if one touches before the other, you have to make some adjustments. Say the right rear tire touched down first, you can either take away some preload from the left front shock, or add some preload to the right front shock, or a little bit of both. When you get both tires to touch at the same time, move on to the other end of the car.
Speedo
Speedo is offline   Reply With Quote
Old 10-28-2001, 10:11 AM   #17
Yokomo Fan's Avatar
Originally posted by TSR6
Yokomo - Or get a "Third hand" ... Its a little stand with 2 alligator clips, i am tempted to get one, but i always find some way to get the job done...
TSR6:
I think i saw a pic of this "third hand" stand, in rc car action website, it seems as a good idea! Do you by any chance know where to get one? or just a hobby shop? as per usual.
Yokomo Fan is offline   Reply With Quote
Old 10-28-2001, 04:55 PM   #18
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Yeah, HobbyShops should have them, or be able to get them. We accually stock them quite often. We have even had a cool one with 2 aligator clips, and a magnifying glass. They are made by the same guys who bring us the great X-Acto blades to slice our fingers with.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-28-2001, 07:58 PM   #19
benraldo the ho's Avatar
Send a message via AIM to benraldo the ho
Hello, don't know if this is a "good" tip or not, but I have not found any adverse side effects. I took all my ball-cups off and put shock o-rings over the balls, then replaced them. Seems to cure up any slop, especially in the steering.
benraldo the ho is offline   Reply With Quote
Old 10-29-2001, 11:21 AM   #20
Yokomo Fan's Avatar
And this can probably make " taking off the ball cups " alot easier seeming that youo won't need to twist it 180* to take it off.
Old 10-29-2001, 11:35 AM   #21
RCTech Member #2
TSR6's Avatar
Just make sure it doesnt bind. I did this on my Nitro RS4, and it accually created a binding problem on some of the steering ballcups...
Troy
RCTech Member #2
Old 10-29-2001, 12:07 PM   #22
You can find a third hand at your local Radio Shack. Mine has two alligator clips and a magnifier.
FastAggie is offline   Reply With Quote
Old 10-29-2001, 03:11 PM   #23
Yokomo Fan's Avatar
Hi,
How much did it cost you approx. ?
thanks for the help!
Old 10-29-2001, 07:09 PM   #24
Mine cost about $10-$12.
Old 10-29-2001, 08:36 PM   #25
Trader Rating: 69 (100%+)
how do you remove the anodizing from aluminum parts?
marvi is offline   Reply With Quote
Old 10-29-2001, 08:53 PM   #26
RCTech Member #2
TSR6's Avatar
Everyone says EZOff works if you soak it overnight, but i havent tried it personally...
Troy
RCTech Member #2
Old 10-29-2001, 09:17 PM   #27
is ezoff a brand of solvent or something? i think its not available from where im from. is it similar to laquer thinner?
Old 10-29-2001, 09:23 PM   #28
how do you anodize parts
was ist los? is offline   Reply With Quote
Old 10-29-2001, 09:28 PM   #29
Send a message via AIM to ZER01
TOURING CAR TIPS
Keep your tires in a zip lock bag. They'll stay fresh. I use the new "Ziplock" freezerbags.
Balance your wheels(w/the tires mounted and glued), you'll see the differance when you run them.
Thats it for now, maybe more later.
ZER01 is offline   Reply With Quote
Old 10-29-2001, 09:52 PM   #30
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Marvi - I think he meant EasyOff oven cleaner. It works. Well.
BigDogRacing is offline   Reply With Quote
Odd Posts Timing Only Post by People who only post for sale section? mtx33 R/C Items: For Sale/Trade 25 06-20-2008 11:14 AM
POST YOUR TECH TIPS AND VIDEO HELP FOR NITRO RED-LINE M03 Nitro Off-Road 5 09-23-2007 09:27 AM
Tips. Infamouz Nitro On-Road 1 02-09-2007 06:13 PM
need some tips on tc4 steelhawke Rookie Zone 0 01-23-2007 02:36 AM
Tips on what car to buy.. ownage Electric Off-Road 8 11-04-2002 05:21 PM
