Old 12-30-2002, 12:51 PM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Default Comm Drops, Questions
I am wondering exactly what does comm drops do for you? In particular, the Trinity Black death comm drops.
I used some of these recently to see what they would do on my motor, ,and the power increase was great. I was told to use 1 drop on each brush and them leave them alone for the rest of the race day until I clean the motor and brushes thoroughly.
I want user experiences, not bashing or blantant praising. Also, what kind do you recommend?
I am running a 19T Chameleon 1 motor. I will be looking into a Pro match storm2 later on.
Old 12-30-2002, 01:00 PM   #2
sosidge's Avatar
Well, my experience with comm drops has been...
1. 30secs of incredible power from the motor
2. Rest of the run normal
3. Motor gets filthy
So I stopped using them, and didn't lose any time.
Some people seem to swear by these Tribo drops though...
Old 12-30-2002, 01:08 PM   #3
popsracer's Avatar
Guys;
From what I've read about the Tribo Drops is that they act more like a lubricant and reduce friction between the brushes and the com without causing the build-up like regular com drops.
I personally do not use any drops for the same reasons that Sosidge stated.
popsracer is offline   Reply With Quote
Old 12-30-2002, 02:59 PM   #4
Tech Legend
Cain's Avatar
The drops I got off another racer seem to give a lot of power throughout the run. Other racers are using the Trinity 2000 Comm drops or the nitech ones that seem to lubricate the brushes and comm and work well. I will probably go with the Revtech drops as they are not heavy on the comm like the black death ones I have.
Old 12-30-2002, 03:42 PM   #5
Regional Moderator
Send a message via AIM to Mike F
Originally posted by popsracer
Guys;
from my own personel experience, I use the TRIBO drops and they work great. My comm is cut less, my brushes last longer, and I can gear it 1 or 2 teeth higher then without.
Do I have to clean it out, yes. I clean it out after every run then re-apply. I know, it seems like a lot to do but the stuff really works.
Mike F is offline   Reply With Quote
Old 12-30-2002, 10:16 PM   #6
Neil Rabara's Avatar
I only use drops for breaking in of new brushes. Not for racing. Keep in mind that if you do use drops, the lubricant will attract dirt and grime into the motor.
Neil Rabara is offline   Reply With Quote
Old 12-31-2002, 11:11 AM   #7
Same results here.
dalem is offline   Reply With Quote
Old 12-31-2002, 11:06 PM   #8
Trikster's Avatar
Ditto. I went about 15 runs between cuts on the com and a full season on one set of brushes. Tribo works really well.
Trikster is offline   Reply With Quote
Old 01-01-2003, 06:12 PM   #9
university_dave's Avatar
Get some Tribo. It really does make a difference over the whole run.
university_dave is offline   Reply With Quote
Old 01-01-2003, 08:59 PM   #10
you guys that are using Tribo...how do you use it? reapply every run? Clean out and reapply every run? Or only use on a clean comm?
I have some and tried it last weekend, and it seemed to increase wear on the comm. but I may not hae been using it properly. I started with a fresh comm, and applied a drop before each run without cleaning or anything else.
You guys that are having success, I am curious as to how you are using it successfully.
Hey, if Mike Reedy and Jim Greenemeir (sp?) swear by this stuff, there must be something to it...
markg is offline   Reply With Quote
Old 01-02-2003, 06:54 AM   #11
Rob68's Avatar
I have been using the Zubak's Speed Juice with great results. I think it works like the Tribo, you put some drops down the back side of the brushes. It doesn't seem to wear off like normal comm drops, and I am gettng more life out of my brushes and comm.
Rob68 is offline   Reply With Quote
Old 01-02-2003, 06:01 PM   #12
I apply one drop through the side of the endbell and then rotate the arm before a run. After each run I give a quick blast of cleaner into the endbell and reapply the Tribo.
My comm wear (stock) has gone way down with the Tribo. With 4499 brushes and red/green springs I was lucky to get 10 runs without a comm turn and had to take .002-.003 off the comm to clean it. Now I get at least 15 and I am taking less (.001-.002) off the comm when turning.
Old 01-02-2003, 07:04 PM   #13
skibum989's Avatar
Where can i find some of these Tribo drops? None of my LHS's have it, and it sounds like something I wanna try.
skibum989 is offline   Reply With Quote
Old 01-02-2003, 08:49 PM   #14
http://www.kthobbies.com/store/motor...ccessories.htm
Best comm drops raceGEEK Electric Off-Road 3 09-22-2007 11:06 AM
where to buy Tribo comm drops Jmccormick Electric On-Road 17 02-26-2007 03:09 AM
Who uses Tribo Comm drops? Do you like them? JLMG1971 Electric On-Road 29 04-04-2005 05:29 PM
Mod motors and comm drops bigdog xxx-s Electric On-Road 8 08-26-2004 10:15 AM
Comm. drops? conti64 Electric Off-Road 1 02-02-2004 09:48 PM
