Like Tree73Likes
ARC A10-25
Old 05-01-2024, 01:53 PM
  #46
Just noticed this in the manual.
Figured not many of us scroll past the part of installing electronics .... But they give you an idea for caster.
Though you do need an extra set of hex's that use a grub screw.
Or a 2mm tip will fit right in the slot on the actual hub. I think thats what they are showing.
Just food for thought
Robbob is online now
Old 05-01-2024, 05:28 PM
  #47
gigaplex's Avatar
Given the play in the screw head, this will only give an approximation. Not particularly accurate.
gwhiz likes this.
gigaplex is offline
Old 05-01-2024, 05:40 PM
  #48
Agree but close enough for quick track changes to try, drivers with out a caster doodle and government employees.
Old 05-01-2024, 05:44 PM
  #49
I don't think that is what they are showing. You can never be sure your wheel hexes would be in the right position (motor cogging thang). That's the slot built into the hub itself.
Only explanation I can find for this screw honestly.
Robbob and tbrewer187 like this.
Carnage9270 is offline
Old 05-01-2024, 06:43 PM
  #50
gigaplex's Avatar
We're not talking about the wheel hex, we're talking about the 2mm hex head driver tool
gigaplex is offline
Old 05-01-2024, 06:53 PM
  #51
I was speaking to what Rob eluded to...he's was talking about a set of hexes with a grub screw. That's not where you want to measure caster from. Place the driver in the slot in the steering block (which he mentioned as well) and you can tighten it down (or capture it tighter) with the cap head screw in my pic.
Robbob likes this.
Old 05-04-2024, 02:39 AM
  #52
J SiN's Avatar
This car doesn't have grub screws in the hex's
The 2mm driver fits snugly in the slot but I would recommend getting the Smokem caster gauges for the 25
The Teacher and Robbob like this.
J SiN is offline
Old 05-12-2024, 06:39 PM
  #53
Got to run the '25 saturday on carpet. Smooth, very predictable and for sure durable.
Only lost a front body post but luckily the track had a drop in replacement.
I found myself chasing the rear all day but not to keep it under the car.
I was finding as the track was getting faster and bite was coming up I was developing on power pushes.
Mid to exit I could grab more throttle but it was a feather to keep the front steering. Add some dual rate each round and it exited with power.
Not a bad thing but now I wanna find more natural steering in the car.
Very happy though with a new platform for me, super happy with the parts I was testing too.
Im also playing with something from my Mi8 days that they made into the 9.
I found ARC makes a lower 5.8mm pivot ball that drops the RC 1.5mm compared to kit.
They sell them 2 per pack but I couldnt find 4 packs in the states so I went to the BD7.
Their shock mount pivot balls are 5.8mm and 1.5mm shorter. Drop right in - plenty of movement and opens the tuning up some more.
Didnt have those on but they are now for the next track day.
rccartips, gwhiz and blwaz23 like this.
Old 05-18-2024, 02:52 PM
  #54
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Krazedbuilds has some goodies !!
https://krazedbuilds.com/shop/arc-a1...w8Cyr67pTTWq3G
Mach10_shooter, Robbob and Typeone like this.
Marcos.J is offline
Old 05-26-2024, 03:18 PM
  #55
Super Moderator
Marcos.J's Avatar
flipping the hubs work just fine( not my car its Team Driver EC Kim)
Tizianino likes this.
Marcos.J is offline
Old 05-27-2024, 07:50 AM
  #56
When you flipped the hubs what was the gain?
topfuelhobbies is offline
Old 05-27-2024, 07:54 AM
  #57
Super Moderator
Marcos.J's Avatar
use the AMX caster doodles for one plus what’s the advantage of using them the other way ?
Marcos.J is offline
Old 05-27-2024, 02:13 PM
  #58
Lower CG like Schumacher and Xray?
gigaplex likes this.
rccartips is offline
Old 05-27-2024, 04:35 PM
  #59
Super Moderator
Marcos.J's Avatar
possibly but unnoticeble from the driverstand lol
Marcos.J is offline
Old 05-28-2024, 03:45 AM
  #60
They're virtually symmetrical when you measure from the axle center to either mounting side.
Not really any CG change, def not any thats gonna have a pro/con change.
It will change the way the rear toe reacts and the front bump steer.
Marcos.J likes this.
