Like Tree44Likes
Yokomo MS1.0
Old 04-27-2024, 07:02 AM
  #46
gwhiz's Avatar
Nothing stopping you from ginning up an AMX/Schumacher style upper arm arrangement and adjust caster in fairly fine increments with turnbuckles.
However this does introduce an obligation, in my opinion, to adjust and check camber and caster more regularly than with a fixed upper arm. Some people dislike this.
gwhiz is offline
Old 04-27-2024, 11:17 AM
  #47
Yes apparently if you want to adjust caster, you need to buy the dual top link. I think in an interview during last speed king tour race, the car designer says it will not be included in the box.
But I didn’t heard something about optional bulckhead… sound strange to me!
It is a nice car I think and the price is more affordable. But the spares…. It can be a problem with yokomo today, if you look at the rs1.0 there is shortage on a significant amount of part since it release.
Tom6440 is offline
Old 04-27-2024, 12:21 PM
  #48
Leaving this here is anyone find it useful: https://site.petitrc.com/reglages/yokomo/setupms1.0/
Arn0 is offline
Old 04-28-2024, 09:40 PM
  #49
It's the same old Yokomo adjustment using a spacer under the front bulk head that also messes with the ride height (easy fix) and the dive. And with spacers what do you gain? 1/2 a degree?
I don't under stand it. Good luck factory racers in competing this year.
MylesB is offline
Old 04-28-2024, 10:30 PM
  #50
Typeone's Avatar
Trader Rating: 50 (100%+)
Seen this car in person. Nico was here in Bakersfield testing at finishline. Car looked good on the track. Think he might've had the prototype because the black aluminum was in silver.
Typeone is offline
Old 04-28-2024, 10:50 PM
  #51
gigaplex's Avatar
Er, that won't work on this car
gigaplex is offline
Old 04-29-2024, 01:45 AM
  #52
How do you change the caster then?
MylesB is offline
Old 04-29-2024, 02:01 AM
  #53
gigaplex's Avatar
There's no C hub, you need to change the positioning of the upper arms. Without seeing the manual I can't say with certainty whether there's a kit option, but you could swap the top arms with dual turnbuckles.
gigaplex is offline
Old 04-29-2024, 03:27 AM
  #54
kentech's Avatar
From Yokomo product presentation:
"The A-type upper arm newly adopted in MS1.0 is a resin-integrated type that is easy to adjust, and a turnbuckle adjustment type that allows you to freely change the alignment is also sold as an option."
Manual is also available here: https://teamyokomo.com/product/msr-010/
Tom6440 likes this.
kentech is offline
Old 04-29-2024, 10:57 AM
  #55
Thanks for the confirmation.
Tom6440 is offline
Old 05-02-2024, 02:22 AM
  #56
Nice play of words "alignment". You should of said what it really is. Everything except caster. When they make a car you can change the caster i will have one in my cart otherwise i'm going with the Mi9 by the end of May.
MylesB is offline
Old 05-02-2024, 01:01 PM
  #57
Will27's Avatar
Yes, the dual top link setup which will be available as an option lets you freely adjust alignment, including caster. Lengthen the front link and shorten the rear link simultaneously moves the top of the hub back, increasing caster. You can freely adjust it as stated
gigaplex likes this.
Will27 is offline
Old 05-02-2024, 01:17 PM
  #58
ChrisP's Avatar
Not sure it's an attempt to make a play on words...just a translation that didn't return the output you expected...Caster will still be adjustable with the dual link.... (like it is on the Mi9)....
ChrisP is offline
Old 05-02-2024, 05:37 PM
  #59
gigaplex's Avatar
I'm not sure why you're so obsessed with finding a car with adjustable caster when you don't seem to grasp the basics of how it works. The turnbuckle type is exactly how the Mi9 works.
gigaplex is offline
Old 05-03-2024, 04:28 AM
  #60
I will just need to wait for the adjustable turnbuckle to come out as an option then. It will be the first time you see anything in the Yokomo manual or factory racers setup sheets on caster settings. I like the mention of a fiixed hub carrier benefit so the caster doesn't get tweaked. It would be nice if you could buy different degrees of fixed hub carries and their cheep. Racing is about corner speed and adjusting caster is part of that equation.
MylesB is offline
