Like Tree374Likes
Tamiya TRF 421
Old 01-30-2024, 12:16 AM
Default Tamiya TRF 421
News from Nuremberg
AndreasHerold is offline
Old 01-30-2024, 01:03 AM
cansoykal's Avatar
Looks like mtc2 doesnt it?
dawgmeat and gigaplex like this.
cansoykal is offline
Old 01-30-2024, 01:11 AM
More pics:
Tamiya 42384 TRF421 Chassis Kit at Nuremberg Toy Fair 2024 - TamiyaBlog
Old 01-30-2024, 01:40 AM
Regional Moderator
disaster999's Avatar
Nice MTC2 in blue. To be honest, I was hoping Tamiya would throw in more of their own flair. At least they still insist on using plastic arms and hinge pins
Edit: saw wrong, its pivot ball suspension
gigaplex likes this.
disaster999 is offline
Old 01-30-2024, 01:46 AM
kentech's Avatar
Description:
https://kentech.wordpress.com/2024/0...ption-details/
Photos:
https://kentech.wordpress.com/2024/0...ots-of-photos/
Raman, gwhiz, Sir 51D3WAYS and 2 others like this.
kentech is offline
Old 01-30-2024, 01:56 AM
What do you mean by hinge pins?
Old 01-30-2024, 02:02 AM
kentech's Avatar
First TRF421 specific parts with part numbers from Tamiya.
42385 45mm Lightweight Rear Swingshafts
42386 TRF421 Wheel Axles
42387 Drive Shaft with Low Friction Double Cardan Joint (2 Pcs.)
42388 Axle Shafts for TRF421 Double Cardan Joint Shaft (2 Pcs.)
51738 TRF421 Damper Oil Seals
51739 TRF421 A-Parts (Upper Arms)
51740 TRF421 BB-Parts (Rear Body Posts)
51741 TRF421 C-Parts (Uprights)
51742 TRF421 D-Parts (Suspension Arms)
51743 TRF421 Damper Parts
51743 TRF421 Drive Belt
51744 TRF421 Front Direct Pulley (37T)
51746 TRF421 Gear Differential Set
Bonezero and Raman like this.
kentech is offline
Old 01-30-2024, 02:14 AM
Dan the Man's Avatar
Trader Rating: 41 (100%+)
I'm betting I couldn't get one in Australia for under $1500 Aussie Rupees. I'll be shocked if any Aussie shop will stock it, unless you special order it.
MonkeyCmonkeyDo likes this.
Dan the Man is offline
Old 01-30-2024, 04:17 AM
Will see how it runs in TITC 2024. Surprised, a kit far different from the prototype being tested last year. I'm a Tamiya fan but not a fan of this copy that does not even bring anything new to the table. Might as well copy the latest (i.e MTC2R) and not the 2020 version
racing_jason and gigaplex like this.
rccartips is offline
Old 01-30-2024, 04:31 AM
gwhiz's Avatar
I'm happy Tamiya is at least still in the ring.
gwhiz is offline
Old 01-30-2024, 04:55 AM
R/C Tech Elite Member
And if it had adjustable 4link everyone would call it tAMXiya
No hinge pins .... pivot ball suspension.
Looks like lots of room for Factory upgrades. Just wish Tamiya's werent a house payment to own in the States.
Good to see though theyre still thinking hardcore racers.
Robbob is offline
Old 01-30-2024, 06:18 AM
Nice.
MIght pick one up used for a few hundred bucks in 10 years time.
Bloke is offline
Old 01-30-2024, 07:56 AM
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
I'll have to pick one up possibly for TCS GT1 and maybe use it for VTA (matches the new spec motor color!) in the off-season.
Looks like no aluminum chassis is included with the kit?
Dan is offline
Old 01-30-2024, 08:05 AM
Raman's Avatar
Trader Rating: 96 (100%+)
Well Dan, it appears they listened to you,., those TA08 arms didn't have the right "geometry" for a TRF car.. so they redesigned them lol. I for one appreciate the plastic lower arms. Breaking carbon arms is not cheap.. unless you are running a 3Racing Cero.
More interestingly.. the XM-01 Pro answers a proper M Chassis 4WD rallye chassis, versus the MF-01X. Now I know where to put the Fiat 131 body 😉
angrymelon likes this.
Raman is offline
Old 01-30-2024, 08:10 AM
Raman's Avatar
Joel, No one will ever be happy with Tamiya. If they continued with the 420X style, feedback would be Tamiya is just releasing kits. They finally changed to lower and upper arms like MTC2 and now it's.. they copied A, B , C Brand etc. All current 1/10 chassis in truth have copied Awesomatix. The only thing they haven't copied is their shock design.
At the end of the day, Tamiya only cares for feedback from its racers in Japan.
Lonestar, Buckland and DirkW like this.
Raman is offline
