Like Tree378Likes
Tamiya TRF 421
Old 04-24-2024, 02:56 PM
  #196
gigaplex's Avatar
Originally Posted by Raman
Did you have to reference the peanut brittle C hub from 418/419 area... some of us still have ptsd.. 🤣 The 420 version were much better.. the weak point became the steering upright... I switched to the Xray T4 hubs on my car and didn't have any more issues.
Sorry not sorry 🤷‍♂️
gigaplex is offline
Old 05-08-2024, 01:01 AM
  #197
zuqbu's Avatar
Originally Posted by Robbob
Any links to the cf chassis alone and stocking or date to release?
Part number is 3404156 according to Modellbau Seidel.
We should see a release very soon. Or does anybody here have it already?
zuqbu is offline
Old 05-08-2024, 08:18 AM
  #198
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
Tower told me a shipment at end of April and one in May. But still have not received mines.
Dan is offline
Old 05-09-2024, 10:45 AM
  #199
kentech's Avatar
Have posted some TRF421 things from the Shizuoka Hobby Show in the last two days, including an interview with the designer. Check blog if you're interested
https://kentech.wordpress.com/
Souta Goto TITC car:
zuqbu, mr.rev, Tom6440 and 1 others like this.
kentech is offline
Old 05-10-2024, 12:54 AM
  #200
It seems he was running X-ray or axon springs on his car?
Tom6440 is offline
Old 05-10-2024, 04:13 AM
  #201
I've notice in the article this: "Below a first look into the new TRF USBB dampers, showing the new upper seals which now sits recessed in the damper body."
This is quite unusual isn't it? A feature to keep long shocks body and +20mm springs? Or maybe to improve the sealing of the damper and it build?
And many thanks for the translation Kentech.
Tom6440 is offline
Old 05-10-2024, 06:34 AM
  #202
Probably just the same shock bladder design as the Mugen and Schumacher.
gigaplex likes this.
rccartips is offline
Old 05-10-2024, 07:46 AM
  #203
gigaplex's Avatar
Most brands these days have moved to that style of bladder.
gigaplex is offline
Old 05-10-2024, 02:00 PM
  #204
ChrisP's Avatar
Who else is doing 'upper seal recessed in the body'? Most have a similar looking bladder, but the seal is still sandwiched between the threads above the top of the body and the cap?
I'm looking forward to detailed build pics and manual for this car to get a better look at the fine details....
ChrisP is offline
Old 05-10-2024, 02:03 PM
  #205
Yes that was my point Chris.
Tom6440 is offline
Old 05-10-2024, 02:47 PM
  #206
Xray are.
ChrisP likes this.
Rick Draper is offline
Old 05-10-2024, 03:11 PM
  #207
gigaplex's Avatar
Mugen, Xray, Schumacher, ARC all use recessed bladders on their latest cars. Yokomo/Axon do not. Not sure about other brands.
ChrisP likes this.
gigaplex is offline
Old 05-10-2024, 03:43 PM
  #208
Tamiya is only 4 years late to the party with recessed bladder.
Old 05-10-2024, 09:16 PM
  #209
and your tt02 can keep up with most modern cars. So how important is it to have shocks with recessed bladders?
Raman and Autostrada048 like this.
Juan Aveytia is offline
Old 05-17-2024, 02:56 AM
  #210
zuqbu's Avatar
Two german RC stores collaborated and have uploaded an unboxing video yesterday (video is in German and the camera is unfortunately positioned very far away):
https://youtu.be/rh4ZrBHMIE4?si=LiqqZavVieU0myvS
Not that much new information in there, a couple of notes:
  • They discuss that it would be possible to replace the upper suspension arms with multiple links (like f.e. Awesomatix)
  • Caster seems to be a variable adjustment, the markings are there to set specific angles
  • Internal gear ratio is confirmed to not have changed (still 1.85)
  • Ball bearings have rubber sealings not teflon
  • 22086 titanium turnbuckles are included and used for upper arm camber links
  • They think the release will most likely be in early June
Another german store has all the specific spares listed and on sale from what appears to be a disassembled kit. So either dealers got an early sample or they already have stock but Tamiya is enforcing a release date. (unlikely, see below)
Edit: One person seen in the video, Dai Sakaguchi has uploaded a scan of the manual. He also says he will fulfill orders as soon as he gets the kits.
zuqbu is offline
