fried my motor dont know why
I have a T2 and the motor was a monster co27 the pinon gear is a 24. I think it might of been geard to low. what do you guys think?
It is impossible to tell.
It depends on what size track, what size tires, if you're drive trane is free (as in not causing unncessasary strain on your motor) and how long you have driven the car since you last turned the motor, and if you ran an entire pack till it was dead.
Yeah check your drivetrain, it should run smoothly. For gearing, normally what I do is run for a few minutes and see if the motor is hot. If its just too hot to touch, use a smaller pinion.
I did run the batteries till the car started to slow down. Im getting a new motor from teambroad whats a good stock motor they offer.
IB4200
there are a lot of factors to consider regarding your fried motor. But first, you need to compute for the Final Drive of your car when using certain motors.
Spur/pinion(internal ratio)=Final drive
It also depends on how the racetrack is(lay-out, size)... i gear my 27T motor from 7.10-6.90 on small tracks, and on long flowing tracks i go down to 6.75...
hope this helps.
There are two types of Tbrood 27T motors the epic base and the monster base. Epic base is an RPM motor and the monster base is a torque motor. (correct me if im wrong).
and one thing more avoid over running your motor... 5mins run is enough, if u still want to run more let your motor cool first before you run again.
ayt!!!
ayt!!!
thanks curious mind my final drive ratio was 5.95 and I ran it for more than 5 min just doing quick pulls of the trigger in my garage to test the car out. I have a FT tc4 (battery was lipo) and I did the same thing and my gear ratio was 6.0 and never once did the motor start smoking.
5.95 is way to high for CO27. Go somewhere in 6.5+ range.
Ill try that gear ratio next time when i race. thanks guys
