TC3 Assembly Tips, Factory Team Kit >
Old 01-10-2003, 01:33 PM
  #61
Trader Rating: 27 (100%+)
Default Gear Ratio and Tire Selection
I have come to the conclusion after running stock some mod and 19 turn on the indoor asphalt here at ReflexRC that the majority of tire heating on a touring car comes from accelerating. We need to use softer tires for stock than for 19 turn even though cornering speed is about the same. Last night geared 7.4 my Sorex 32 tires were a little loose and failed to heat up properly. The higher gear had detuned the car just a bit which resulted in less tire heat. Pitz 30's worked alright with this gear. I returned to the 7.5 gear and Sorex 32's for the main. Even though it had cooled off the tires hooked up well.
If you have better corner speed the car needs to accelerate less, you can get by with a little softer tire at the same temperature. Another racer that is not quite as fast may tear up the same set of softer tires if he is not not going as fast around the corners. You can also get by with higher gear ratio (more pinion teeth) if your corner speeds are higher. This also reduces the heating of the tire.
Any thoughts on this subject would be appreciated.
John Stranahan is offline
Old 01-11-2003, 11:18 AM
  #62
robk's Avatar
Trader Rating: 22 (100%+)
Mike D:
What are you changing when you go to the spool?
thanks
robk is offline
Old 01-11-2003, 01:01 PM
  #63
Mike D's Avatar
robk - When running the spool most of your suspension changes are to make the car steer into the turn harder. On power the spool feels exactly like a oneway - very good steering. Off power the spool makes the car understeer. Compared to a front diff setup, the spool setup has softer front end and/or stiffer rear end, batteries back, more front tire compound (for foams), shorter wheelbase, more front droop/less rear droop, etc...
Mike D is offline
Old 01-13-2003, 11:40 AM
  #64
I aggree with the changes Mike suggested for the Spool. I made all of those changes on a Losi XXXS when running the spool. Have not run a spool on the TC3 yet.
When running the spool the front tires on the Losi tended to heat faster than the back causing excessive front grip midway in the race. The solution was to move weight back in the car.
Old 01-14-2003, 04:31 PM
  #65
Default Roll Stiffness and Roll Center Changes
I did a couple more experiments today to address a couple of handling problems.
Corner entry push.
I was having a little corner entry push coming off the straight around a hairpin. I reduced the front shock oil from 40 to 35 to address this problem. Seemed to help.
Increased Roll Stiffness
The car was stalling on occasion (slowing severely in the middle of the corner). I thought I needed the top of the shocks moved out one hole to increase the roll stiffness front and back to ease the car around the corners. The front had a blue spring all the way out, so I thought I would try the rear shock tower on the front as I have seen. This provides two holes further outboard than the front tower. It also lowers the shock bodies which might be good or bad. It lowers the center of gravity, but it reduces uptravel when going over the plow disks that mark some of our corners. Iíll see how it works out. I used the middle hole for the upper shock position with the blue spring. Outer hole for the upper rear shock mount with the silver spring.
On Power Push
I was not able to apply as much power in the corners as with my previous car due to a little more push than Iím used to. After adjusting the springs, I tried moving the rear camber links inner pivot to the lower position. This raises the roll center a bit. Anyway this helped the rear rotate a little better on power which reduced the onpower push. The lighter shock oil helped this a bit as well.
Iíll edit the setup I posted previously on page one. The car seemed easier to drive on the indoor asphalt with these settings.
Old 01-15-2003, 10:57 AM
  #66
Default Increasing Front Uptravel
I'm using the rear shock tower on the front now. You can increase the ammount of uptravel of the front wheels by removing about 1/16" of material off of the top of the lower spring mount. Remove material untill it is flush with the top of the plastic shock end. This might prevent bending of the upper shock mount screw in the crashes and will allow smooth driving over plow disk type corner markers without flipping the car over.
Old 01-15-2003, 11:36 AM
  #67
51
51's Avatar
John: Are you using the new outside hole on the front arms when you went to the rear tower in the front? I've found that when running the rear tower on the front it's almost always better in the outside hole in the arm. I was experiencing the "stall" you were refering to until I made this change. Outside will also result in a bit more uptravel.
Keep up the good work, we appreciate it!
51 is offline
Old 01-15-2003, 02:34 PM
  #68
51- Thanks. I am in the outside hole on the A-arm. I'm not in the outside hole on the shock tower yet. I put the two shock towers together and it appeared that the rear tower has two holes further outboard than the front tower. I'm in the middle hole, which makes the shock a little more upright than before. I'll race it tomorrow night and see if I need a little more stiffness.
Old 01-17-2003, 09:48 AM
  #69
Default Smooth Gear
Hi,
I have been building a FT TC3 for few days and notice that
when I spin my drive train with out gear case covers(F/R) spins very nice and free. However once I install a cases, both front and rear, drive trains become very heavy and it seems that gears are binding very tight.
I have build my car according to a instruction and I just wanted to know what is causing it and possible solutions before start to modify a gear cases.
Thanks for your help.
J.
DoCoMo is offline
Old 01-17-2003, 10:04 AM
  #70
Northerner's Avatar
more then likely its the gear cases compressing the diff bearings
remove some material a very little at a time on the case opening with a dremel and keep checking untill everything is spinning freely!
Northerner is offline
Old 01-17-2003, 10:30 AM
  #71
Jayhaya-To check if the gear cases are compressing the bearings install only the diff without the input shaft and install the cover see if ithe diff spins free. Then do this with the input shaft installed and no diff. Install the cover and see if the input shaft spins free. If both spin free alone then the problem is probably gear mesh and not bearing compression. Remove one or two shims from the input shaft to gain a little bit of play in the gears. On my car the shafts spin free but I had to remove two shims from the input shafts before I had a little play in the gears.
Old 01-17-2003, 03:08 PM
  #72
Default Aluminum Shock Caps
I got the Blue Aluminum Shock caps installed. They are a better fit to the stock plastic nuts and won't bind up. There was some leakage on the first attempt. I lifted the o-rings a little with a pointed tool with the shock cap off so that they would seat better inside the shock cap. This solved the problem. If you are ordering them I would get a new set of o-rings. They really should come with them to avoid this problem. The Blue Aluminum Nylock nuts will also fit with these caps with no problems.
I am told the plastic caps hold more shock oil. Surely can't tell by just looking at them.
Old 01-18-2003, 04:49 AM
  #73
dw
Jayhaya - did you remove the seals on the diff bearings? If you did and reinstalled them then make sure they are seated properly or this will cause the problem you describe.
dw is offline
Old 01-18-2003, 05:48 AM
  #74
Thanks for all your help. It seems that removing a shims from input shaft did a trick.
Thanks again.
J.
DoCoMo is offline
Old 01-18-2003, 05:02 PM
  #75
Default Gritchy Steering Rack
My steering on the TC3 was funny sometimes. On moving the wheels back and forth by hand it felt like I had trashed the servo gears in a couple of spots. I removed the servo link from the servo and the steering links from the knuckles and the problem was in the rack. The ballbearings tend to roll rubber bits into the rack and it stays there and builds up. It was easy to remove with the rack in the car by scraping the inside of the rack with the backside of an x-acto knife. Then move the rack and scrape the rest. Back to normal.
Put in a KO digital servo which gave me good service in the other car. Had to remove a little bit of the ears near the bottom only, but then it fit OK.
