TC3 Assembly Tips, Factory Team Kit >
Old 01-07-2003, 05:52 PM
  #46
Trader Rating: 27 (100%+)
Default 64 pitch gears
Ran a 104/35 *2.5 =7.42 gear today. Felt good in the car with a 19/2 Chamaelion on our tight indoor track. Ran a 7.36 also which felt a little sluggish to me. Christian is running a 7.2. I tried to install a 112 spur. It would fit with slight chassis mods but the motor would not move far enough out without cutting on the blue motor support cam. Decided a 104 and a 100 would be the spurs to have in 64 pitch.
John Stranahan is offline
Old 01-07-2003, 09:12 PM
  #47
Trader Rating: 47 (100%+)
hey guys kinda off the subject your talking about, but I just got a new factory team tc3, and everything went together fine in assembly. But it seems my gear mesh in both trannys is off, and the car runs kind of loud because of this. I have tried moving the spacers on the bevel gears and even removing one, but nothing seems to help. I have run the car for two weekend races thinking maybe the gears would seat themselfs but no luck. Does anyone have sugesitons or tips on this problem
porter is offline
Old 01-08-2003, 01:35 AM
  #48
seaball's Avatar
what do you fellas lube your gears with?
seaball is offline
Old 01-08-2003, 03:21 AM
  #49
Post
Associated diff grease (no black) is what you need to lube those gears
Proto pilot is offline
Old 01-08-2003, 04:51 AM
  #50
i use associated diff grease and RB Plum crazy tapered gear lube, nice stuff.
Jarrod Langlois is offline
Old 01-08-2003, 08:42 AM
  #51
Default Aero-Car gear lube
I use Aero-Car gear lube. It comes with a tiny brush that with some modification will actually go thought the gear cover hole and go down and touch the pinion gears in the gear case without disassembly. It looks like a light bodied paraffin that melts as soon as the gears turn. It leaves a very light coating of lubricant on the gears so that they don't stick as they rotate.
I see some listed at this hobby shop. Your local hobby shop should be able to order some.
http://www.happyhobby.com/hobb_html/aerocar.htm
Porter-Try removing one or two shims from the input shafts. Some guys even run the car with no shims.
Drive Shaft O-ring
I thought that this O-ring would be a constant source of endthrust on the pinions and their bearings so I did not install it. Seems to work fine without it.
Old 01-08-2003, 11:07 AM
  #52
Northerner's Avatar
i use IRS diff lube in a resealable syringe. its very handy, you get alot and its cheap! about $5 a tube!
if anyone wants some, were a direct dealer for IRS
click here to email me directly
Northerner is offline
Old 01-08-2003, 02:13 PM
  #53
Default Blue Aluminum Shock Caps
Here is the Associated part # 1598
This might cure the problem of the plastic shock nut's flange binding on the shock caps as well as having more uniform size to the hole that the bushings rotate in. I don't have a set yet so I'm not sure on either. About $12.
SPOOL
Solid front or rear spool. Associated part # 1704. This is made for the NTC3. Don't know if this will drop into the TC3 The only difference might be the outdrives as the two cars share a heavy duty one-way housing. If you know for sure please let me know. About $30. There are several other companies including IRS and Wolfe that make spools as well.
Old 01-08-2003, 05:38 PM
  #54
John,
The nitro stuff is not the same, I think the center of the one-way is the same but the inserts are not (hopefully someone can correct me if I'm wrong). If I wasn't so darn lazy I would walk down stairs and see for sure, if I need to let me know.
Ted
Ted Flack is offline
Old 01-08-2003, 10:42 PM
  #55
Ted,
Hi,
I think your right. as I can't find mine....... (I even looked!) as for you being lazy.your just worn out from not turning right.... good luck to you and Bobby at the SnowBirds.
John S.
Thanks for starting this thread. I always read your threads at the other place. found them to be enlightening. hope you have fun with your TC3.
Fakk2 is offline
Old 01-09-2003, 12:10 AM
  #56
Smile
What you guys think about that IRS straight front axle to TC3? I looked it from Towerhobbies site and it`s not so expensive for my mind 21.99$, but how strong it actually is because it is aluminium? Any experience...??
Old 01-09-2003, 09:41 AM
  #57
We have some IRS spools on order. They have not arrived yet so I don't have a durability report.
Old 01-09-2003, 10:01 AM
  #58
Mike D's Avatar
Proto pilot - My IRS spool works great on carpet with an 8x2. No signs of wear or breakage. However, to reduce wear you should use the irs pin cushions. I used the irs oversized cvd bones (with pin cushions) when I ran the spool. I used to bend the associated cvd's when I ran the oneway. I figured better safe then sorry when using the spool.
Mike D is offline
Old 01-10-2003, 12:09 AM
  #59
Mike D: Thanks, for input, maybe that was the thing what i wanted to hear
Edit: I just made order to Tower and now waiting those parts...
Old 01-10-2003, 10:59 AM
  #60
Thumbs up
I`d like to test when i got those parts, how fast my TC3 Ft will be... in spring race series
