Old 04-21-2003, 10:27 PM   #316
CristianTabush's Avatar
Zigzag, run lighter oil in your car than stock... Try 30 or 25 wt oil (all around on your car)... will make a world of a difference..
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-21-2003, 11:24 PM   #317
Send a message via AIM to Genetic Send a message via Yahoo to Genetic
yeah ive seen those stainless steel spools.. nice, how much do they usually go for?
Genetic is offline   Reply With Quote
Old 04-22-2003, 07:09 AM   #318
Send a message via Yahoo to ZigZagRC
im running 30 weight with #2s...im thinking about moving the front shock position to the inside on the top.
~ZigZag
ZigZagRC is offline   Reply With Quote
Old 04-22-2003, 08:52 AM   #319
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
zigzagRC-If the rear end is loose coming out of the corner you could try increasing rear toe out from 2 to 3 degrees per side. If the car pushes mid corner you could try increasing caster by 2 degrees by using the 2 degree caster blocks along with your 2 degrees of kickup. Moving the top of the front shock one hole in will give you more steering traction mid corner but might make the problem exiting the corner worse.
John Stranahan is offline   Reply With Quote
Old 04-22-2003, 09:35 AM   #320
cool thanks man, i'll definatly try the castor blocks, what are the advantges of them? also what would a lighter weight oil do to the car in the corners? i need to get a little more cornering speed out of the thing, if i used lighter oil would i have to compensate with a higher spring rate?
~ZigZag
Old 04-22-2003, 10:52 AM   #321
Send a message via AIM to munrath
Cristian,
Are you and Barry running the same setup as last year for the Tamiya and Worlds race? If not, could you post the setup somewhere.
Also are you planning on attending the Nats in June located in NC?
Thanks,
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 04-22-2003, 10:57 AM   #322
CRASH's Avatar
Trader Rating: 26 (100%+)
Play with IRS Gear Adaptor
spaz456, I have the IRS gear adaptor and also noticed this. So did the stub axle washers remove this play completly. I haven't noticed it affecting my cars performance though, have you? Will have to give that a try tonight, it is race night.
Later,
CRASH is offline   Reply With Quote
Old 04-22-2003, 11:11 AM   #323
Send a message via AIM to Johnnytc3
munrath,
barrys setup is on team associated website... its almost indentical to the one he was using at reflex ... the only difference i can think of was he changed his oil to 25 all around and took off the rear sway bar for his mains. I might not be right about the oil although i did see him redo all of his shocks.
Johnnytc3 is offline   Reply With Quote
Old 04-22-2003, 03:18 PM   #324
sorry thought you were refering to barry...
Old 04-22-2003, 03:45 PM   #325
Crash-i used 2 stub axle washers and it seemed to removed alot of, but not all of, the play. it seems much better with this.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 04-23-2003, 08:51 AM   #326
ZigZagRC-The caster blocks will increase midcorner steering traction. Caster improves front traction when the car is rolled over the most in a turn and also when there is maximum steering angle; this is mid corner. More caster will decrease initial turn in because the car is not rolled over much initially. Try the lower shock oil with the same springs. If the car lacks precision in its high speed steering then go to stiffer springs.
Old 04-23-2003, 12:31 PM   #327
Right on John, thanks for the info. i wont be able to race this saturday due to a wedding in my family, but that will let me save my moolauhh up to buy those blocks lol. i'll definatly give you the results, and maybe some more questions...later
~ZigZag
Old 04-23-2003, 12:31 PM   #328
John, where can i get the book everyone is talking about??
~ZigZag
Old 04-23-2003, 12:37 PM   #329
Check my WWW above.
Old 04-24-2003, 07:54 AM   #330
does anyone know the part number for the graphite conversion that comes with the droop screws? also what is the best bearing set for the tc3
jiggamacdaddy is offline   Reply With Quote
Team Associated 1/8 scale Truggy Info and Tips Kevin Boyle Nitro Off-Road 4505 11-14-2017 12:51 AM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 04:31 PM
TEAM DON'T CROWD ME...TIPS FOR PIT SPACING TeamButter Florida Racing 3 10-26-2006 05:51 AM
FS: Factory Team NTC3 with Sirio Evo 2 World Champ Engine, K Factory, MX3-S Radio.. R3VoLuTiOn R/C Items: For Sale/Trade 11 09-23-2006 08:37 AM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
