Tamiya BT-01 Chassis (RWD/FWD) >
Like Tree32Likes
Old 10-30-2023, 03:18 AM
kentech's Avatar
Default Tamiya BT-01 Chassis (RWD/FWD)
New 2WD BT-01 TC sized chassis offers choices of FWD or RWD drive system.
First car kit on this chassis: 58733 Toyota Supra (JZA80) (BT-01)
New BT-01 Chassis
• Length: 397mm, width: 185mm. Wheelbase: 257mm / 251mm (*).
• The 2WD BT-01 chassis gives a choice of two types of wheelbase (*), and front- or rear- wheel drive system.
• Without removing battery pack, motor and R/C equipment setups from the center frame, simply change attachment directions of final gears and steering linkage to switch between front- and rear-wheel drive; front (FR) or midship rear (MR) motor position can be chosen for rear-wheel drive cars.(Six setups are available in total.)
• The 4-wheel double wishbone suspension features symmetrical structure and friction dampers.
• Unitized sections such as motor mount, final gears and suspension facilitate ease of assembly and effective maintenance.
• Many Hop-Up Option parts for TT-chassis cars can be used to fine-tune setup.
Full details: https://kentech.wordpress.com/2023/1...wd-tc-chassis/
angrymelon and BuggyFan21 like this.
kentech is offline
Old 10-30-2023, 05:45 AM
gigaplex's Avatar
Looks like it shares some parts with the MB-01.
gigaplex is offline
Old 10-30-2023, 06:58 AM
sosidge's Avatar
Indeed it does.
I can see what Tamiya are doing here, very cheap RWD/FWD chassis as a body holder for touring size bodies. And in a sense I'm pleased to see Tamiya offering a "scale" drivetrain for those bodies rather than 4wd.
But I struggle to get excited by it. MB-01 that is is based on has very limited steering, this is probably the same. They haven't even bothered to launch it with a brand new body set.
Raman and Revolter22 like this.
sosidge is offline
Old 10-30-2023, 07:16 AM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
It probably won't even be much cheaper than a 4WD TT-01 or TT-02.
gigaplex likes this.
Dan is offline
Old 10-30-2023, 08:58 AM
Killa-Cotton's Avatar
Trader Rating: 20 (100%+)
Cool. But you won't be able to get one for months.
Killa-Cotton is offline
Old 10-30-2023, 09:36 AM
simple's Avatar
I get the sense from releases like this that Tamiya is carving out a "Duplo" level market niche.
simple is offline
Old 10-30-2023, 10:16 AM
It's really hard to beat a car that's all of like 25 parts. That said, I think the BT-01 is a better car. We'll need to see though.
Nerobro is offline
Old 10-30-2023, 03:17 PM
gigaplex's Avatar
What makes you think the BT-01 will be better?
gigaplex is offline
Old 10-30-2023, 03:34 PM
angrymelon's Avatar
Looks like out of the box adjustable toe front and rear maybe?
angrymelon is offline
Old 10-30-2023, 03:41 PM
gigaplex's Avatar
Losing 4WD will have a far bigger performance impact than that.
gigaplex is offline
Old 10-30-2023, 06:55 PM
Sir 51D3WAYS's Avatar
I think you guys may have to compare it with the old FF series chassis for a fairer test.
Revolter22 likes this.
Sir 51D3WAYS is offline
Old 10-31-2023, 04:47 AM
I can't speak for the BT01, but its smaller MB01 brother has better steering out of the box than the TT02.
I guess let's compare it to the FF-02 then (basically an M03 on steroids), the FF-03 was more racey and came with little things called ballbearings and oil filled shocks iirc.
Revolter22 is offline
Old 10-31-2023, 06:33 AM
gigaplex's Avatar
I have an MB-01. The steering limiters on the arms severely hampers the turning radius and the car has garbage handling compared to an M03. I'm not sure how you're comparing the steering of a 2WD m-chassis to a 4WD TC.
gigaplex is offline
Old 10-31-2023, 08:17 AM
It comes with droop adjustment. It's steering sits on larger pivots and isn't dependant on step screws.
We'll see. I need to pick one up and try it out.
Nerobro is offline
Old 10-31-2023, 09:30 AM
