Tamiya BT-01 Chassis (RWD/FWD) >
Like Tree35Likes
Old 10-31-2023, 10:27 AM
  #16
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Pretty tough to compare apples to oranges. Unless you're wanting something unique (nothing wrong with that), I'd rather get a TT-02 which is probably the same price point as the BT-01. I'll buy an BT-01 in the future if it comes equipped with a body that you can't buy separately.
A big reason I didn't buy the MB-01 mini since I already have the older minis and an M07/M08.
Revolter22 likes this.
Dan is offline
Old 10-31-2023, 12:45 PM
  #17
Originally Posted by gigaplex
I have an MB-01. The steering limiters on the arms severely hampers the turning radius and the car has garbage handling compared to an M03. I'm not sure how you're comparing the steering of a 2WD m-chassis to a 4WD TC.
I was rushed for time with my previous response. I've driven my MB-01 in its RWD setup with a decent metal servo horn (the kit servo saver is terrible), the steering feels better as it uses ballbearings.
It does handle worse than previous entry level M-chassis, both due to the weight/bulk of the chassis and the weight distribution.
What you and others have said about the turn radius is no joke. My MB01 just gets driven about on the street, but the limited turning combined with its weight (its only slightly lighter than a TT-02), has been an issue. I have to steer with the throttle like I'm powersliding an old buggy around!
Revolter22 is online now
Old 10-31-2023, 03:56 PM
  #18
gigaplex's Avatar
Originally Posted by Nerobro
It comes with droop adjustment. It's steering sits on larger pivots and isn't dependant on step screws.
We'll see. I need to pick one up and try it out.
The large pivots on the MB-01 pop off very easily. I don't consider them a win.
gigaplex is offline
Old 10-31-2023, 03:58 PM
  #19
gigaplex's Avatar
The steering only uses ball bearings if you upgrade them. The kit uses bushings.
gigaplex is offline
Old 10-31-2023, 04:33 PM
  #20
Mine popped a pivot as I was just driving on the road in front of my house, I didn't even tap anything.
I like having the option to install bearings around the steering bellcranks without a hop-up.
Old 11-01-2023, 04:44 PM
  #21
Raman's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Dan
It probably won't even be much cheaper than a 4WD TT-01 or TT-02.
I’m going fully salty on this release!
For a while now we Tamiya fans have complained about our favourite rerelease bodies coming on TT02 chassis.
Tamiya as a result has decided to punish us insolent westerners with the fabulous all new BT-01. 😂🤣😂🤣
Dan likes this.
Raman is offline
Old 11-01-2023, 04:49 PM
  #22
Raman's Avatar
By pivots you mean the balls you press into arms? If so, they’re the same as TT02. If you push them in per manual you should be ok. If you compress too much then they will pop out. Easy fix is the low friction metal ones from TT02.
Qatmix, ruebiracer and Revolter22 like this.
Raman is offline
Old 11-01-2023, 05:17 PM
  #23
That's what I meant yea, either washers or low friction balls work, I ran a set of low friction balls in it after that and I didn't have it happen again. A nice side effect of the metal TT02 balls is that they reduce slop too.
Raman and ruebiracer like this.
Old 11-10-2023, 07:40 AM
  #24
The more that I look at this chassis, the more confused that I am. The TT-02 does the whole "cheap touring car kit" thing fine enough, it has a better steering angle than my MB-01, and the TT can run with other basic touring cars on the market.
This seems more niche, I can’t see the FWD setup competing in a FWD class, and without steering angle mods it'd be a poor drifter. It'll have to be really cheap (or play up the "scale" aspect) to sell.
Old 11-10-2023, 10:06 AM
  #25
Raman's Avatar
Stop looking at it and wasting your vision. 😵‍💫 no good will come of it
Raman is offline
Old 11-18-2023, 12:40 AM
  #26
kentech's Avatar
BT-01 displayed at Tamiya Fair / World Chmpionships 2023 this weekend.
More images: https://www.facebook.com/blogkentech...y692pYmZ7jTFel
angrymelon likes this.
kentech is offline
Old 11-18-2023, 03:49 AM
  #27
rccartips is offline
Old 11-19-2023, 03:08 AM
  #28
sosidge's Avatar
Hadn't realised that this also offers a front-motor-rear-drive option. I think that's a first? Certainly adds to the "scale drivetrain" appeal of the chassis. If I was buying a Supra to drive up my street before putting on a shelf, I'd want it to be in FR configuration rather than a 4wd TT-02.
sosidge is offline
Old 11-19-2023, 04:14 AM
  #29
gigaplex's Avatar
I want to see how the driveshaft passes by the battery in that configuration.
gigaplex is offline
Old 11-19-2023, 08:26 AM
  #30
sosidge's Avatar
Battery over the top.
Obviously terrible for CG but this is not, and never will be, a performance chassis. It's a cheap, semi-scale-accurate body holder.
angrymelon and Revolter22 like this.
sosidge is offline
