weight scale or tweak station
hi im just confuse ,or just wanna know if i can use a weight distribution scale made buy integy, or use a tweak station ,to check my tweak... cause on tweak station your checking which side got more weight than the other right? while on the weight scale its the samething.is it possible that i can either use the scale??
just needed some expert advice..thanx
Scales are good at home when you first setup a car with electronics to get the weight in the right place. After that you can just use the MIP tweak station at the track to set your corner weights right. You cannot use the tweak station to set the weight right in the car. You can use scales to the set the corner weights at the track but they are on the delicate side and bulky to transport.
Is Integy digital weight system any good? It's the one with 3 stands for 3 of the axles and the fourth axle rests on the scale. I know that you have to the move the chassis or the scale so that you get a ready which is a pain. But is it a good system to figure out your weight distribution?
im gonna figure it out sooner im bidding right now on a integy weight scale.... im just confuse on which to use if i use the scale and if its not balance can i adjust the preload? to balance it... cause i dont think putting physical weight will help..while in tweak station you can just adjust the preload..
newbie. need advice
newbie. need advice
newbie. need advice
newbie. need advice
have 4 of THESE and they work great.........the price is right also and they are small. I f you get diferent ones , make sure they are at least 500g. li
THEY ARE KINDA EXPENSIVE..I JUST BID ON THIS CAUSE ITS STILL CHEAP.. BUT I JUST WANNA KNOW WHICH ONE IS MORE USEFULL I MEAN EASY TO USE CAUSE IN THE TWEAK STATION YOU JUST HAVE TO ADJUST THE PRELOAD(PRIOR TO THE DROOP AND RIDE HIEGHT,) CAUSE IM RUNNING A T2 RIGHT NOW AND A COUPLE OF TWEAKS HERE AND THERE AND ITS A CHALLENGE FOR ME TO HANDLE THAT SITUATION.
Hi slotmachine,
I also want to buy these scales but i wonder if they are al exact the same height. If not then you will get false readings. When you set your tweak with the scales and you change the scales from place ,do you still get the same readings as before?
Grtzz
Grtzz
