Old 04-26-2006, 08:51 AM   #1
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Default Spools...
I just wanted to see what people thought about spools and there affect on cars (drive trains, wear on parts, breakages, etc.). I have had both a JRXS and Schuie:EC and run mod in both and both cars have held up very well.
My expereiences have been:
The JRXS tends to wear out the plastic composite outdrives and it has the LCD to be able to run 100% steering throw without 'chattering'.
The EC wears out 'blades' to protect the outdrives and cvd pins.
Both cars have broken or bent nothing due to the spool.
What have been other people's experiences with spools??? (cars like the 415msx, cyclone, T2, BD)
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 04-26-2006, 09:47 AM   #2
I used a period with spool on my pro4. Had to change bevel gears almost 2 weeks or less. It will have more wear and tear on the transmission of course more breakage. Since the spool doesn't bulge, something else must break right? But eventually I still like my pro4 best when it is running on spool.
ah_liang is offline   Reply With Quote
Old 04-26-2006, 10:35 AM   #3
AM03GT's Avatar
with the car setup for it, the spool is a pretty good option. been running one for a few months in preparation for RROC. with a little grease on the outdrives i have zero pin wear... as for ring gears on my TC4, only on hard impact does it ruin a gear... only broke one in the last 2 months...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 04-26-2006, 11:05 AM   #4
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
you might want to check your mesh I have the pro 4 with the spool running mod and the bevel gears still look brand new, I have worn out the out drives a little bit but is still in almost new condition.
Old 04-26-2006, 12:47 PM   #5
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
I run a spool in my Xray '04 and as long as you throtle smooth the wear seems to be less of an issue
PEACE OUT
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 04-26-2006, 01:58 PM   #6
RaceAce701's Avatar
Trader Rating: 86 (99%+)
diff vs spool vs one way wat are the handling characteristich of each
i run on carpet and use a one way in my cyclone and like it but im lookin at the alternatives
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 04-26-2006, 02:00 PM   #7
teabag's Avatar
those of you with spools are you running with a center one way? or no center one way?
teabag is offline   Reply With Quote
Old 04-26-2006, 02:59 PM   #8
2-Bad's Avatar
Trader Rating: 24 (100%+)
My centre pulley is locked (no one-way). I would imagine that running a centre one-way would defeat the purpose of running a spool diff.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-26-2006, 03:10 PM   #9
TryHard's Avatar
I run the delrin outdrive spool on my MSX. As it's light (about 7g) it really helps the car retain great turn-in. Regards durability, it can be a little fragile indoors, but then I usually run a 1-way or diff. I think in my whole time since running one (about a year) I've only broken two outdrives (one off the yump at bedworth, and the other against a roll of carpet)... so not too bad. No chatering either.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 04-26-2006, 04:42 PM   #10
Thumbs up
I run a solid center pulley setup
Spools DC Racing Electric On-Road 3 05-15-2007 10:34 PM
Lockers/Spools???? spittindurt Monster Trucks 3 01-16-2006 10:45 AM
One Way, Diffs and Spools? Fervidsea Electric On-Road 4 10-29-2005 08:13 PM
one ways/spools greencactus3 Electric On-Road 37 04-03-2005 10:31 AM
Understanding spools... Soviet Electric On-Road 39 06-18-2004 03:11 AM
