Old 04-26-2006, 06:17 AM   #16
Send a message via AIM to rcguy2477
Originally Posted by hpipro321
...not the smartest thing to post...dont want 12 year old kids telling there dads that they were told its ok to rip a sub-c cell appart and end-up hospitalizing them selves because a metal shard cut their wrist...
good info though
Good point. If you want to take apart a sub-c sized cell, make sure you have adult supervision.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 04-26-2006, 07:54 AM   #17
cannon's Avatar
Trader Rating: 35 (100%+)
And the funny part is that the majority of our racing cells are hand made. I know because I visited a factory in China. Man, we must be killing heaps of Chinese workers. There is very little worker protection.
cannon is offline   Reply With Quote
Old 04-26-2006, 08:01 AM   #18
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Some adults I know out there may need adult supervision.
JC1000
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-27-2006, 03:54 AM   #19
JC1000
Great that mean I need my wife's supervion if I decide to opean cell.
cyrrus is offline   Reply With Quote
Old 04-27-2006, 06:13 AM   #20
Metal Hydride doesn't sound that harmful... unlike Cd...
semper is offline   Reply With Quote
Old 04-27-2006, 08:55 AM   #21
Birky's Avatar
James, your going mad
Heres another view of the inside of a cell. (2006 Australian Off Road Championships)
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 04-27-2006, 12:44 PM   #22
The materials they are working with arn't nearly as bad as Cadmium. We are killing ourselves at a much faster rate with some of the chemicals used around the track.
1989 Mazda Rx7
Old 04-27-2006, 01:04 PM   #23
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Which is why the cells are not made in the U.S. Add worker protection, unions, factory emissions restrictions - and the cells would cost a lot more than they do today. Ever hear the term "pollution exporting?"
Good point on the battery recycling. If you have dead battery packs, check out http://www.rbrc.org/ for a location near you that recycles batteries. I know of a couple hobby shops that used to have battery drop boxes - but no longer do.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-03-2006, 05:33 PM   #24
BATT_MAN's Avatar
Jason,
GREAT POST....
All our conversations and long talks have paid off.
It is GREAT to see you sharing this information with the RC world.
I would like to add some points about the NiMh cells... and I think I mad a long explanation on the IB3800 thread... or maybe on a discussion between NiMh and LiPo...
Well, here it goes....
WHAT Nickel/Metal Hydride (NiMH) Cells are made of.
Anode: Rare-earth or nickel alloys with many metals
Cathode: Nickel oxyhydroxide
Electrolyte: Potassium hydroxide
This sealed cell is a hybrid of the NiCd and NiH2 cells. Previously, this battery was not available for commercial use because, although hydrogen has wonderful anodic qualities, it requires cell pressurization. Fortunately, in the late 1960s scientists discovered that some metal alloys (hydrides such as LiNi5 or ZrNi2) could store hydrogen atoms, which then could participate in reversible chemical reactions.
In modern NiMH batteries, the anode consists of many metals alloys, including V, Ti, Zr, Ni, Cr, Co, and Fe.
Except for the anode, the NiMH cell very closely resembles a NiCd cell in construction. Even the voltage is virtually identical, at 1.2 volts, making the cells interchangeable in many applications. Here are the cell voltages at the anode and cathode: (Jason already wrote the equations, so just use the voltages for each one of the equations)
The Anode (2nd equation) has a voltage of 0.83 volts
The Cathode (1st equation) has a voltage of 0.52 volts
The Overall reaction (3rd equation) has a VOLTAGE of 1.35 volts
The anodes used in these cells are complex alloys containing many metals, such as alloys of V, Ti, Zr, Ni, Cr, Co, and (!) Fe. The underlying chemistry of these alloys and reasons for superior performance are not clearly understood, and the compositions are determined by empirical testing methods. We have experimented for years and time after time we find better ways to get a better discharge curve and higher efficiencies.
Intellect has done a superb job of finding the correct alloys in order to produce one of the BEST NiMH cells in the industry.
A very interesting fact about these alloys is that some metals absorb heat when absorbing hydrogen, and some give off heat when absorbing hydrogen. Both of these reactions are bad for a battery, since it s better fotthe hydrogen to move easily in and out without any energy transfer. The successful alloys are all mixtures of exothermic and endothermic metals (IB has found them!)
The memory effect, which was at one time thought to be absent from NiMH cells, is present if the cells are NOT treated right. To avoid the memory effect, we recommend to observe and follow our prescribed maintenance techniques.
At one point we found that by completely discharging the batteries every 15 cycles we got rid of the memory effect. However, due to newer manufacturing techniques and better alloys, we do not recommend this procedure anymore. There are better procedures to keep the cells operating up to 90% od their SoC for up to 40+ cycles.
I hope this will help.
BATT_MAN is offline   Reply With Quote
What's inside your battery? CarlosG. Electric On-Road 7 10-26-2007 01:58 PM
Inside R/C Brian Anthony Electric On-Road 9 06-13-2006 03:46 PM
Ride Height Gauge, Nexus Digital Caliper, Motor Heat sinks, Battery jig pics inside RED-LINE M03 R/C Items: For Sale/Trade 9 05-25-2006 04:38 AM
Everything Must Go !!!!! Look Inside ----------> rubasu R/C Items: For Sale/Trade 38 10-25-2005 07:41 PM
Inside R/C Speedie Electric On-Road 1 12-15-2003 05:41 PM
