Old 04-25-2006, 04:15 PM   #1
Greenbandit's Avatar
Default Spektrum problem
I am running a spektrum system with an LRP Q2 speedo. My sponsor wants me running the full spektrum system, so I have been running their servo as well. I decided to try a high speed JR servo, but found that it will not work with the system. It glitches very badly only when turning the wheel fast?? I called Spektrum and they tell me that the Q2 does not put out enough voltage to allow a high speed servo? I never had that problem with my airtronics radio gear? Has anybody run into this problem? I was told by Spektrum that I would have to run a capacitor on the speedo to correct the problem. I have heard from a fellow racer that this did not work for him. Any input would be much appreciated.
Todd Daly
Greenbandit is offline   Reply With Quote
Old 04-25-2006, 04:25 PM   #2
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Its a common problem, and what Spektrum told you is correct, except that you run the Spektrum capacator and plug it into the reciever.
v0rtex is offline   Reply With Quote
Old 04-25-2006, 04:48 PM   #3
Thanks very much. Appreciate it.
Todd Daly
Old 04-25-2006, 05:06 PM   #4
Ok, here's another dumb question. I will be running the the new Spektrum Telemetry system as well. With steering, throttle and transponder already plugged into the receiver, how can I run the cap along with the Telemetry? Can I run a Y somewhere in the system, or will this somehow overload the receiver? Sorry for not being extremely electronically inclined.
Todd Daly
Old 04-25-2006, 05:25 PM   #5
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
Just plug the transponder into the channel 3 socket on the rx. All it needs is power so it can be plugged into any open plug on the rx.
RcCzarOfOld is offline   Reply With Quote
Old 04-25-2006, 05:45 PM   #6
That's the problem. It is a 3 channel receiver and there is not enough plugs for everything. 1:steering, 2:throttle, 3: transponder, 4: capacitor, 5: telemetry system.
Todd Daly
Old 04-25-2006, 05:55 PM   #7
2-Bad's Avatar
Trader Rating: 24 (100%+)
I’ve attached my cap two different ways; solder directly to the pins inside the case of the receiver, and solder directly to the pos+ neg- of the transponder wires…. Your choice… either way will give you space to attach the telemetry plug...
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 04-25-2006, 06:34 PM   #8
Thanks, I will give it a shot.
Todd Daly
Old 04-25-2006, 06:57 PM   #9
aN4rK1's Avatar
Looks like 2bad answered your question bandit. Hes running all five things and its not overloading the reciver so I would get a Y plug just to keep everything neat instead of soldering.
aN4rK1 is offline   Reply With Quote
Old 04-25-2006, 08:31 PM   #10
hpipro321's Avatar
or you could go down to your local rc plane store and buy a splitter that splits one terminal into 2...problem solved
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Problem with spektrum in my M8 James Tanous Radio and Electronics 6 07-19-2008 12:50 PM
yet another spektrum problem cm367700 Radio and Electronics 11 12-19-2007 10:10 PM
spektrum problem blowpopracer Radio and Electronics 2 10-20-2007 06:46 PM
spektrum problem associatedguy Radio and Electronics 5 10-20-2007 03:43 AM
Spektrum DX3.0 problem MikeXray Electric On-Road 0 06-03-2007 06:13 PM
