Old 12-27-2002, 12:44 PM   #1
Canuck's Avatar
Trader Rating: 25 (100%+)
Default Parking lot tires (24mm) - suggestions please !
Anyone have any suggestion for inserts and tires that I should use for parking lot racing (asphalte)?
I have a YOKOMO YR-4M2.
Thank's
Canuck is offline   Reply With Quote
Old 12-27-2002, 08:54 PM   #2
popsracer's Avatar
Default I hate to do this to you
Canuck;
I really hate to do this to you, but try using the search option. There was a really good thread a couple of weeks ago about parking lot tire selection and you should be able to pull it up in a search. Use "parking lot tire or tires" for your search parameters.
popsracer is offline   Reply With Quote
Old 12-28-2002, 12:05 AM   #3
skibum989's Avatar
Sorex, Pit Shimizu, and Take Off all make great tires for asphalt racing. I personally use Take Offs for asphalt and they work great.
skibum989 is offline   Reply With Quote
Old 12-28-2002, 02:55 AM   #4
Canuck's Avatar
Thank's "Popsracer" I found the thread !
Old 12-28-2002, 03:40 AM   #5
Canuck's Avatar
Look's like I will try the Yokomo 138G's with HPI 24mm red inserts.
Thank's Popsracer.
Old 12-28-2002, 05:36 AM   #6
Canuck's Avatar
I found a set of YOKOMO HOT LAPS XT-4MNR. Anyone know if they are good tires ?
Old 12-28-2002, 08:18 AM   #7
Regional Moderator
Darkseid's Avatar
Try the Take-offs pre-mounted tires. They make them in C22, C27, and C32 compounds and they go for like $34. Its a really good deal on really good tires. Plus they come mounted on multispoke wheels, and not dish wheels!
Thats about all most people ran around here last during the outdoor season this year.
TLR 22...Tamiya F104...
Old 12-28-2002, 11:41 AM   #8
Canuck's Avatar
What do you recommend C22, C27, or C32.
The track is asphalte - parking lot. Temperature is not like Texas here but mostly moderate like upper 70's .
Old 12-28-2002, 02:02 PM   #9
Trader Rating: 24 (100%+)
Try the 27's first. i'm in Florida and they have been great in 60 degree weather all the way to the 90's. Be advised....they have much better grip when they are warm or have a couple of laps on them. Good Luck
Evoracer is offline   Reply With Quote
Old 12-28-2002, 08:26 PM   #10
popsracer's Avatar
Default Yokomo's not labeled
Canuck;
Make sure you label the inside of your rims with a felt marker when you mount a new set of tires. The Yokomo's are not labeled on the sidewall with the compound like the Take-Off's and Sorex's are.
Old 12-28-2002, 09:38 PM   #11
sugesttions for outdoor cold weather i live and race by d.c. and the weather is allways changing
bob's tc3 is offline   Reply With Quote
Old 12-29-2002, 04:08 AM   #12
Canuck's Avatar
Another good tip from "Popsracer" re. the labelling ! I see you've been at this for a while....
I'm going to stick with the YOKO 138G and HPI red inserts.
Thank's
Old 12-29-2002, 12:42 PM   #13
popsracer's Avatar
Default Labeling and Storing
Canuck;
Another thing to do is, keep your extra sets of tires in a "Zip-Lock" baggie to keep then from dring out.
The Yoko 138G's and HPI Red inserts should work fine on Rough asphalt. As a Second choice tire, pick up a set of Team Sorex 36R's and more HPI Red inserts. This will give you tires that will work on any asphalt surface.
If the asphalt is older and rough (weathered) then the 138G's should be better. On Fresh or resealed asphalt, the 36R's usually will out-grip the Yokomo's.
Take-Off 27CS's would be a good for a 3rd set of tires. You can usually buy the Pre-mounted sets cheaper than doing it yourself.
Old 12-29-2002, 01:15 PM   #14
Canuck's Avatar
Thank's Popsracer !
Old 12-30-2002, 05:29 PM   #15
Canuck's Avatar
Hey "Popsracer" , some people are saying that the YOKOMO will only last 2 or 3 runs ! Is that true or just a pile of *&%*&? ...
They are saying that the TAKE OFF tires CS27 are better !
FS: PIT SHIMIZU TIRES 24mm JoeyE R/C Items: For Sale/Trade 0 12-30-2007 08:58 PM
Could i put 24mm rims on 25mm tires ? thahookup Rookie Zone 1 04-28-2006 07:28 AM
24mm Foam Tires BringItOn Australia For Sale/Trade 0 03-23-2006 12:29 AM
Where to get HPI 27r 24mm tires DustinR Electric On-Road 6 07-18-2005 12:36 PM
Wanted: HPI 24mm 27R Tires NIB DustinR R/C Items: Wanted to Buy 0 07-10-2005 07:36 PM
