Old 04-24-2006, 03:57 PM   #1
Default Carpet vs asphalt racing
Maybe this is stupid question but what are the main differences in setup for asphalt and carpet racing?
I know that should change tires, next step is dumping (i think). Should i use thinner or thicker oil and springs? What with camber, caster and toe (front and rear).
I know that it depend on the track condition but generally which setting is better for carpet and which for asphalt?
Tral is offline   Reply With Quote
Old 04-24-2006, 04:14 PM   #2
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
one what car?
two generally you need a thinner oil, and softer springs with a larger piston in the shock. camber should be approx. -1 to -2 degrees. toe is about the same. caster varies according to the size of the track.larger track=more caster. smallertrack=less caster. generally.
Z.Hallett is offline   Reply With Quote
Old 04-24-2006, 04:18 PM   #3
Thank you. I have Tamiya TRF415MSX.
Old 04-24-2006, 04:30 PM   #4
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
If you're running foams on carpet, swap the front one-way for a ball diff. I read somewhere that Tamiya dont make a front diff for the 415, but you can build one that works from Yokomo parts.
Go harder with your springs and oil, and stand the front shocks up. Throw on a hard swaybar on the front.
Otherwise have a look at the Tamiya threads here, you're better off asking in an existing thread rather than creating a new one. Also, do a search. Probably been asked before, too
v0rtex is offline   Reply With Quote
T2 007 with carpet and asphalt chassis tarheelquality R/C Items: For Sale/Trade 5 01-08-2008 03:46 PM
Asphalt & Carpet 1/12th's!! JayBee R/C Items: For Sale/Trade 17 10-05-2006 10:25 PM
Asphalt-vs-Carpet dawgmeat Electric On-Road 28 02-14-2006 10:15 PM
What car asphalt/carpet RKeasler Electric On-Road 7 02-19-2005 09:20 PM
carpet/asphalt oil weight kh15 Electric On-Road 5 02-14-2005 12:43 AM
