Ko Propo Mars R - Spektrum Compatibilty
Does anyone know whether I can use the Spektrum Helios Module for my Mars, or is there a seperate module?
thanks
thanks
Thanks Steve! also i heard they were bringing out a Pro series, will they be compatible with Mars
thanks
thanks
losi-sw,
If I had to guess then the pro series would work also with the Mars radio line. Since the size will remain the same and the pins arrangement remains the same the performance gain from the pro series is inside of the module itself, and really its mostly about latency speed.
p.s. have you seen the mini receiver that spektrum is working on. Also there is a specktrum thread that would have more info.
Steve
Steve
ohhh no i havent heard about a mini receiver!! sounds good though. Im just about to order the spektrum for my Mars R. Anyone using it with their Mars System?
I'm using Mars R and having problem binding the module & rx. While the rx binding ready is OK, the module did not blink at all...
Does this mean the module is faulty?
The R works well if using standard module & rx.
Anyone can help? thanks.
