Old 04-22-2010, 06:53 AM   #46
steliosh's Avatar
Originally Posted by Limpan View Post
JKL1031; I believe that is the Toe-adjuster?
Could any of you guys please measure the battery tray on the Sprint? Im probably going to buy a Sprint 2 Flux but I want to know if my lipos will fit.
I have a few of these: http://www.hobbyking.com/hobbyking/s...dProduct=10277
I have these http://www.hobbyking.com/hobbyking/s..._hardcase_pack which are 45mm wide and 23mm high (yours are 46X26), and are JUST fitting, height wise... so, maybe the 26mm 5200 is too high...
www.steliosh.net/rcmoto/
www.steliosh.net/rc/
KP-Designs KP10e 1/5 rc bike, Kyosho Lazer ZX-5, HPI Baja SS, Xray T1 FK05, Venom GPV1 1/8 rc bike, Anderson M5 Cross 1/5 rc bike, TT SB-5 1/5 rc bike
steliosh is offline   Reply With Quote
Old 04-22-2010, 09:10 AM   #47
JKL1031's Avatar
i was told it was ackerman. its not a direct adjustment for toe, as if u keep them both at the same angles, the toe will still be even.
JKL1031 is offline   Reply With Quote
Old 04-22-2010, 12:27 PM   #48
And I assume you're using the top-hole in the battery-fastener-thing..?
Limpan is offline   Reply With Quote
Old 04-22-2010, 12:50 PM   #49
steliosh's Avatar
Of course. We also have an assortment of other hard case batteries, like IP 3800/35C or SP 4000/35C, and these also are the same height: 23mm and fit just tightly.
Even oval-shaped batteries like the YR or Susumu 3200's fit with the battery fastener in the top hole.
Old 04-22-2010, 12:55 PM   #50
Thanks a lot!
Guess im gonna have to get some new batteries then Is there a big different in performance between lets say 25C and 30C? When they are from the same manufacturer and the same mAh.
Also, do you really need a hard case or you're using that just to be safe? Thought of buying a few of these: http://www.hobbyking.com/hobbyking/s...dProduct=10305
Old 04-29-2010, 06:36 AM   #51
31794ty's Avatar
Have any of you put PVC pipe over the tires for drifting? I've seen it done before and don't really want to spend $30 on tires/wheels for sliding around on the street. What size PVC do I need?
Stampede VXL, Mini-T, RC10B4, RC10T, PZ P-51, PZ Ember 2, Eflite Blade MCX/MSR
www.turtletraxraceway.com
31794ty is offline   Reply With Quote
Old 04-29-2010, 06:59 AM   #52
TAT76's Avatar
When I first bought my sprint I did the ABS mod for drifting. I believe its 1 1/2 inch ABS pipe you want. To make sure measure your wheels and then go check. It's really easy to do and they work great for slipping around.
Using my RC's to stay alive during these hard times...
TAT76 is offline   Reply With Quote
Old 04-29-2010, 02:02 PM   #53
russp's Avatar
Well I'm sellin the sprint 2, my daughter wants a ahort course truck
If ya know anyone lookin here's the link
http://www.rctech.net/forum/r-c-item...rade-sale.html
"Never argue with an idiot. They'll just drag you down to their level, and beat you with experience!"
***radiopost.com***Gens ace/hobbypartz.com***Evosports.net
+++Losi xxx-sct 17.5+++Losi 22. 17.5+++losi xxx-sct mod+++
russp is offline   Reply With Quote
Old 04-29-2010, 02:17 PM   #54
TAT76's Avatar
PM sent..
WTB C.W. Sprint car blackdog Oval, Larger Scales and More 3 07-17-2007 10:28 PM
HPI SPRINT 2 blue hornet. Electric On-Road 1 07-15-2005 10:34 PM
rtr tc3 vs. sprint kh15 Electric On-Road 7 07-02-2004 05:19 PM
Sprint ESC ctardi Electric Off-Road 3 05-26-2004 08:06 AM
XXX-S or Sprint dreadful Electric On-Road 9 05-03-2004 08:03 AM
