Old 03-22-2010, 10:10 PM   #31
russp's Avatar
So I picked one of these cars up froma friend of mine the other dayn so far I like it. Its carbon fibered out got some reallu nice stuff. I wanna try to run this at my local track. I'm a dirt guy so I know nothing n road.
So what I'd like to kmow, what kinda tire do you run fo a asfault track, carpet? Also what is a good brushed motor/esc set up?
I'm really tryin to get a feel for it to see if I like the onroad thing or not so for now this car works for me.
"Never argue with an idiot. They'll just drag you down to their level, and beat you with experience!"
***radiopost.com***Gens ace/hobbypartz.com***Evosports.net
+++Losi xxx-sct 17.5+++Losi 22. 17.5+++losi xxx-sct mod+++
russp is offline   Reply With Quote
Old 03-23-2010, 06:50 AM   #32
2xs
Find out what the fast guys at your track are running. I just got back into onroad this year also. I only had the chance to try Muchmore 24* and HPI pro belted slicks.
And I would got straight to a brushless 17.5 setup. The efficiency of the brushless over the brushed motor is crazy. Both my stepson and I were running the same class(Novice TC). His car has the stock 15T, and mine has a Havok Pro ESC and a Ballistic 17.5, and we are both using the same batteries SMC4100. At the end of the 5 minute heats I would top off the batteries. His battery would take 2100 to 2300 and mine would take 800 to 1000ma.
2xs is offline   Reply With Quote
Old 03-23-2010, 03:40 PM   #33
JKL1031's Avatar
CarbonFiber eh?? post some pix.
im not sure if i will but any yet since i run on the STREET. They have began to sell the chassis protectors for the sprint 2 also..
JKL1031 is offline   Reply With Quote
Old 03-23-2010, 09:35 PM   #34
russp's Avatar
So I took the drift tires off an mounted some rubber.
I got a question for ya, under hard acceleration it pulls hard to the right... Check everyrhing I could think of. Now I'm wondering if a underpowered servo could cause this? It came with a cheap jr servo.
Old 03-24-2010, 06:52 AM   #35
2xs
Sounds like the car needs a good alignment. It is hard to say what the problem is without seeing the car run.
Old 03-24-2010, 08:30 AM   #36
russp's Avatar
If I roll slowly on the throttle or hold a speed, its good. Jus when I stab the throttle it pulls to the right
Old 03-24-2010, 10:16 AM   #37
JKL1031's Avatar
I was thinkin the same,,how some take off so good in a straight line. but im willing to bet its the throttle curve. Is your curve linear or progressive? if its just BAM instant max power, then it MAY be normal.
Old 03-24-2010, 11:15 AM   #38
2xs
I was kind of thinking that the car balance might be off just a little as well.
Old 03-24-2010, 11:21 AM   #39
I look at the full graphite chassis pictured earlier and it looks just like an old HPI pro2. There is no reason that this chassis could not handle a good track like any other car today. I was actually thinking about picking up one of these cars as a "fun" chassis for the shear shock value vs the $500 cars out now. Old Pro2s did not have a problem with rear traction and I would say the same for this car just looking at it. Tekin RS, 17.5, cf chassis, optional springs, spool and a rear ball diff should be good to go.
Isaac is offline   Reply With Quote
Old 04-16-2010, 11:26 PM   #40
JKL1031's Avatar
should i get CF top and upper deck, or get some lipos? how much faster am i looking at going from 76amps (3800mah 20c) to150amps(5000mah 30c)
These cars really dont look all that in CF.
Old 04-17-2010, 11:00 AM   #41
Have you checked if thatīs related to the steering slop? It's a farily common issue in this car, it has lots of play. Mostly on the steering bearing.
Rufus2000 is offline   Reply With Quote
Old 04-21-2010, 02:41 PM   #42
JKL1031's Avatar
can anyone tell mewhat am i adjusting by making this rod shorer or longer? turning sped im guessing?
Old 04-22-2010, 03:25 AM   #43
JKL1031; I believe that is the Toe-adjuster?
Could any of you guys please measure the battery tray on the Sprint? Im probably going to buy a Sprint 2 Flux but I want to know if my lipos will fit.
I have a few of these: http://www.hobbyking.com/hobbyking/s...dProduct=10277
Limpan is offline   Reply With Quote
Old 04-22-2010, 04:32 AM   #44
cyclone x's Avatar
HPI carbon fiber stuff holds up really well you will be fine in the streets
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 04-22-2010, 04:34 AM   #45
cyclone x's Avatar
your doing the toe and the way its set up right now it is rotating in turns fast
Chase Chandler
WTB C.W. Sprint car blackdog Oval, Larger Scales and More 3 07-17-2007 10:28 PM
HPI SPRINT 2 blue hornet. Electric On-Road 1 07-15-2005 10:34 PM
rtr tc3 vs. sprint kh15 Electric On-Road 7 07-02-2004 05:19 PM
Sprint ESC ctardi Electric Off-Road 3 05-26-2004 08:06 AM
XXX-S or Sprint dreadful Electric On-Road 9 05-03-2004 08:03 AM
