Old 04-23-2006, 04:15 AM   #1
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
Default Muchmore CTXC : check clip
guys, anyone here with CTXC charger? recently it shows check aligator clip very often, and i have tried charging 3 pcs of batteries, it just show this error half way charging. i have read from somewhere that changing the tamiya clip to deans connector should be able to solve this problem, but can anyone confirm on this?
had this charger for a about 3weeks, and only few times it occur this error, but since yesterday onwards, i couldn't charge my batteries. pls help me. TQ
btw, i have tried both way, by using the tamiya plug with plug into the battery, and clipping the aligator clip directly into the battery's tamiya plug
uniquexme is offline   Reply With Quote
Old 04-24-2006, 06:15 AM   #2
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Change the tamiya plugs with deans or corally plugs and your problem will be fixed
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 04-24-2006, 06:37 PM   #3
uniquexme's Avatar
ok thanks, i have placed my order on Speedmind deans. btw, i m only to source for speedmind brand, so i was wondering if its really good. but i found it a bit expensive coz its just a simple plug. and btw, may i know how come tamiya plugs seems to have this problem? i mean its just a means of connection and i have checked, everything is connected properly. is it because of its material or something else? but i tried charging it last nite, reduced to 6A, and its ok. kindof wierd sometimes
Old 04-25-2006, 12:59 AM   #4
Shop Owner
nnick's Avatar
When heat rises tamiya plug doesn't cope with it as it should be! I have seen tamiya plugs melt!!
They are great for bashing but if you are serious driver then it's a NO NO
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 04-25-2006, 01:19 AM   #5
psychosilence's Avatar
Had the same problem and could not figure it out. I don't use plugs....always solder ESC directly on battery tab. Anyway, when charging at low Amp rates it would give the **check clip** error. Changed my power supply which was pushing out around 11.5V to a supply giving 13.8V and the problem never came about agin.
psychosilence is offline   Reply With Quote
Old 04-25-2006, 06:55 PM   #6
uniquexme's Avatar
just replaced all my battery connector to speedmind dean plug. However, it seems that the problem still occurs as i tried charging one of my battery : Intellect 3800mah charging with CTX 7A(1/3) 4.5A(2/3) 0.2(3/3), it still says check clip. so i was wondering if the problem is not caused by those connectors. this is because i m using a 12VDC 6A PSU. i know that it is not powerful enough, but can this be the cause? i just can't find any PSU with 10A over the electronic shops here. so other than muchmore power master 20A or 24A, is there any cheaper equivalent PSU? TQ.
Old 04-25-2006, 07:13 PM   #7
aN4rK1's Avatar
your charging at 7amps and your psu is 6amps max? Thats definetly not going to work. If you charging at a perticular amperage then you need a psu at the same amperage or slightly higher to be safe.
aN4rK1 is offline   Reply With Quote
Old 04-25-2006, 08:29 PM   #8
hpipro321's Avatar
your check clip is casued by rou not putting the clip securly on your battery...you do not need to switch to deans just make sure that your clips are securly on your terminals and they wont fall off and look like there still on... if that dosent work...ur charger is busted
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 04-26-2006, 01:08 AM   #9
uniquexme's Avatar
before i changed to deans plugs, i have checked every connection to make sure tat its good. but after i change to deans plugs, its still the same. but d muchmore CTXC comes with factory seal, i dun think tat it will be damaged, unless factory damaged gua. anyway, will try to charge at lower Amp, 5-6A to see how it goes. thanks anyway
Old 04-26-2006, 08:04 AM   #10
As I said before....I had the same trouble. Whenever I tried to charge below 1A I got the check clip error. When I did a CTX charge and it went into the 2/3 0.2A it woul immediately give check clip error. I also use a PSU 10A. Anyway, I then hooked the charger on a car battery and did a step charge and it never got the error at the 0.2A step. Then I did the same test using a 17A lead acid battery that I run my tire truer off and same thing....problem soled. So try charging off a car battery and see if you have any luck.
Psycho
Old 04-26-2006, 08:40 AM   #11
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Use this power supply..
It is cheap and has been reliable for the last two years for me...
http://www.buyreliant.com/psupplies/psv200.htm
Its 20amp and won't drop in voltage as it is regulated.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 04-26-2006, 08:06 PM   #12
uniquexme's Avatar
ok thanks but m looking something near malaysia.
Old 04-26-2006, 11:40 PM   #13
Shop Owner
nnick's Avatar
Xm.. if you are still have the same error maybe you should try to increase the voltage on your PS as arleady proposed. Also check if the batteries are connected correctly. A friend of mine had the same "problem" only to find out that some battery bars were not soldered correctly
Nick
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 04-27-2006, 01:30 AM   #14
uniquexme's Avatar
but mine is stick pack. shd have any problem rite?
Old 04-27-2006, 01:53 AM   #15
Originally Posted by uniquexme
. this is because i m using a 12VDC 6A PSU. i know that it is not powerful enough, but can this be the cause?.
you think
XingXing is offline   Reply With Quote
FS MUCH MORE CTX-D Platinum, CTXC BLUE L.Fairtrace R/C Items: For Sale/Trade 1 09-07-2008 11:24 AM
Much More CTXC Charger 13Zulu Australia For Sale/Trade 2 05-14-2008 04:18 PM
Trade MuchMore ctxc cell master for orion advantage or ice ScottB R/C Items: For Sale/Trade 1 10-15-2007 08:12 PM
MUCHMORE CTXC Charger BlueR1 Australia For Sale/Trade 0 11-17-2006 01:24 AM
Muchmore CTXC : Supply Error, check voltage uniquexme Electric On-Road 7 04-09-2006 06:02 AM
