Old 04-23-2006, 12:01 AM   #1
Jochim_18's Avatar
Default Front Solid one-way
Does anybody here tried a solid front oneway? And can you use your break with this setup? What's the benefit?
Old 04-23-2006, 12:52 AM   #2
ljohnson's Avatar
Do you mean a locked front diff? If so try looking for set ups for your car and a spool (aka locked diff)
ljohnson is offline   Reply With Quote
Old 04-23-2006, 01:14 AM   #3
Jochim_18's Avatar
NO! I'm not talking about the front spool. It's a one way with solid outdrives. Both of the wheels will spins forward a the same time. Both outdrives is connected together. I seen one on ebay it's called "Atomic Solid One-Way Joint"
Old 04-23-2006, 01:17 AM   #4
Jochim_18's Avatar
Follow this link but this one is for MTX4
http://www.rcinfos.com/2006/2006_03_..._diff_mtx4.php
Old 04-23-2006, 01:18 AM   #5
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
I will be trying mine soon, don't think brakes would be that good. It will brake the same as a regular one way, all rear.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 04-23-2006, 01:30 AM   #6
Not exactly, as having both front wheels connected should reduce the amount of entry steering, even though they freewheel like a one way.
Jay Dub is offline   Reply With Quote
Old 04-23-2006, 01:33 AM   #7
Jochim_18's Avatar
I was just thinking about that. Well I just need to get one and find out my self what is this good for. But it will probably work same as the regular one way, But maybe it will make your car a little stable getting off corners.
Old 04-23-2006, 01:45 AM   #8
RKeasler's Avatar
Whether they are connected or not doesn't affect how much brake you can use it will still brake in the rear only. As far as the steering characteristics I agree, it should steer in less than a full oneway.
Rod
ClemsonTigers
USVTA # 224
ERC
Old 04-23-2006, 06:05 AM   #9
414play's Avatar
On a belt drive wouldn't this be like running a spool with a centre oneway.
414play is offline   Reply With Quote
Old 04-23-2006, 06:24 AM   #10
tried it on my 415. yes you can use brakes with a spool. but i never use brakes anyway. drives pretty much the same as a one-way. nothing drastically different.
XingXing is offline   Reply With Quote
Old 04-23-2006, 07:25 AM   #11
Trader Rating: 27 (100%+)
Atomic Multi-Drive for MTX-4
This pretty cool. You can have a oneway or a spool without taking switching anything.
JoeyE is offline   Reply With Quote
Old 04-23-2006, 07:30 AM   #12
...well, at least a locked oneway.
Old 04-23-2006, 08:16 AM   #13
polesitter61's Avatar
The multi-diff for the Xray cars has the same option, full one-way, or a locked one-way which connects the front tires but still lets them spin free under deceleration. It drove like the regular one-way to me, still could not use very much brake.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 04-23-2006, 01:17 PM   #14
anthony390's Avatar
Send a message via AIM to anthony390
all it does is eliminate the independent movement during braking or off throttle
so durring bracking or entracnes your car will be more stable but the tire grip during cornering will be reduced as it will understeer abit more
anthony390 is offline   Reply With Quote
Old 04-23-2006, 04:13 PM   #15
josh69162's Avatar
Send a message via AIM to josh69162
If it will turn in and out like a spool, but you don't get the front breaking of the spool, why not just use a spool?
-Josh
josh69162 is offline   Reply With Quote
Front One Way & Solid Axle vazzo Australian Racing 2 07-16-2007 11:46 PM
Solid front or rear axle for TC3/TC4 DFroyd R/C Items: For Sale/Trade 0 11-07-2006 09:11 PM
solid front axle. stumper Electric On-Road 4 01-08-2004 12:17 PM
Front one way, diff , or solid axle?? Cartman Nitro On-Road 4 05-27-2003 02:39 PM
solid front axle ntc3 MCRUZ Nitro On-Road 6 01-20-2003 08:53 PM
