Old 12-25-2002, 10:43 PM   #1
Default HPI Micro RS4 vs. Kyosho Mini-Z
Which do you like and why? Is one better than the other?
What are the differences?
I did a search but couldn't find a direct comparison.
Thanks!
d2create is offline   Reply With Quote
Old 12-25-2002, 11:26 PM   #2
fasterdanu's Avatar
micro rs4 is faster and it's 4wd
fasterdanu is offline   Reply With Quote
Old 12-26-2002, 01:47 PM   #3
there really isn' much to compare... the micro is almost twice as big, allows you to use standard radio equiptment, and has a 4wd system (altough it is pretty pothetic) The mini-Z is smaller and allows you to run in a much smaller area, the radio equiptment is pretty cheesy (lack of proportional seering) and if you smoke a speedo you need to buy the whole unit which costs as much as the car!!! Also the bodies are polycarbonate (like models) which break and are quite expensive, but last much longer than the micro bodies due to reduced speeds..... The micro can be made much faster (borderline stock tourng speeds), but also becomes more fragile as you add speed..........
Personally I would check out the BRP cars at http://www.brpracing.com/
They are much more durable and just as fast as the micro!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-26-2002, 01:58 PM   #4
skibum989's Avatar
Ahh........ I'd like to post a little bit in the Mini-z's defense b4 the poor thing's reputation is smashed to pieces!
A. It DOES have fully proportional controls - They are made by KO Propo - I don't see how you could fry one, I never have
B. They can be upgraded with faster motors, ball diffs, tires and other various hopups
C. The polycarbonate bodies only get smashed up if you drive like a total HACK.......
Believe me, they are fun cars.
skibum989 is offline   Reply With Quote
Old 12-26-2002, 04:09 PM   #5
hmmm....ok, cool. All good info. I just got the mini-z, but may also pick up a mini rs4 tomorrow since i have the radio equipment laying around. All i need is an esc and battery pack. Any suggestions on that? Also, does anyone know the average length and width of the mini rs4?
Thanks!
Old 12-26-2002, 04:36 PM   #6
Rapid Roy's Avatar
Well the wheelbase on the micro rs4 is adjustable for 140mm or 150mm. The entire car is about 8 inches long and 5 inches wide.
As for batteries, go for a 6 cell pack. Orion makes a good one thats 1100 mah.
The ESC depends on whether you want to stay with a stock motor. If you want to keep all you options open, go for one of the small 1/10 ESCs like the Quantum or the Futaba.
Rapid Roy is offline   Reply With Quote
Old 12-26-2002, 11:50 PM   #7
Trader Rating: 69 (100%+)
for just bashing around, i equipped my micro with 1850 sanyo AA nimh, futaba mc230, and speed 300 motor. the 6-cell AAs have very long run times, even with the 300 motor. downside is theyre heavier than 2/3 A size cells and this matters when racing. the futaba mc230 is inexpensive. its size is just right for the micro. the reverse is a big plus when running around tight spaces, plus it can be disabled for racing.
marvi is offline   Reply With Quote
Old 12-27-2002, 12:18 PM   #8
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Just like to add some info to skibum989's post
A. The miniZ has fully proportional forward, reverse and steering, made by KO Propo no less. The Formula 1 version even has braking AND reverse.
B. They can be upgraded to the moon..... and you can fry the electronics if you use a Tamiya Plasma Dash motor without an external "turbo" (amplifier).
C. Nope, they dun use polycarbonate shells , its the HPI micro RS4s which uses Lexan (polycarbonate) shells. FYI, MiniZ uses styrene (sp) shells... and they are all very well detailed, esp the JGTC ones...no way you can get a Lexan shell to have details like that.
But sad to say, it is possible to smash them up in the heat of a race
The MiniZ and micro RS4 are really two different classes of cars.... the MiniZ can be run gymkana style in the living room.. while the micro really needs more space.
NightKidZ is offline   Reply With Quote
Associated, HPI Micro, Kyosho Mini Z, Xray M18, Losi Mini T unsponsored Australia Wanted to Buy 9 06-23-2017 07:36 AM
Kyosho Mini-Z, HPI Micro and other 1/24-1/28 scale RC Cars Cmotif Micro and Mini Scales 73 06-30-2010 10:27 PM
Wanted-Associated, HPI Micro, Kyosho Mini Z, Xray M18, Losi Mini unsponsored R/C Items: For Sale/Trade 0 05-19-2008 04:54 PM
XSpeed Racing for Kyosho Mini Z, HPI Micro RS4 xspeedracing Malaysian R/C Racers 27 05-21-2004 12:57 AM
Kyosho Mini Z or micro cars wanted!! ccong R/C Items: Wanted to Buy 2 05-13-2003 09:36 AM
