Old 04-21-2006, 04:14 PM   #1
Default stopping traction rolling
Can someone please help me with traction roll. My little brother has a tc4 and we race carpet oval. Everytime he goes into the corner it just rolls over. what is causing this please help. we are running copper rear and purple front springs. double pink all around besides double pink orange right front. please help
James
James605 is offline   Reply With Quote
Old 04-21-2006, 04:36 PM   #2
raptor 700's Avatar
I would put a swaybar in the rear and add a little heavior spring or oil. I run oval on asphat and used to roll until I add the swaybars front and rear heavior shock oil. Hope this helps.
raptor 700 is offline   Reply With Quote
Old 04-21-2006, 04:46 PM   #3
ok i have another question where do you thikn the shocks should be mounted. there are 4 holes on the shock tower. Should theey be in the outside or the inside hole of the tower, and what will the reverse cause? please help, have to have it ready by the morning.
James
Old 04-21-2006, 04:48 PM   #4
beerbarron's Avatar
Too Much Traction! I am joking but really its too much grip. Simple things to try first. How much traction compound are you puting on the fronts? Don't do the whole tire. Leave the hard outer ring untreated. How big are the tires? On carpet I run at 57mm to start. I like them at 56mm. Round the outer edges off also. Next, if the track has a lot of grip, clean the tires after every run. I have been using motor spray and a clean rag. This is what works for me, and I have had lots of issues with traction rolling. One last thing that may be contibuting is a high roll center. Try lowering the roll center by removing shims. I dont race oval .... so my advice may be useless but I don't think so.
beerbarron is offline   Reply With Quote
Old 04-21-2006, 04:52 PM   #5
OKay thats what i thought too about the froont tires so i stopped putting compound on the right front, but it almost looks like it just goes around the corner on the right side wheels for a sec or too then flips. the tires are about 55mm. a local racer told me to use motor spray so i tryed that. i thikn its how the shocks are set really, but i dont know much, thats why im asking
Old 04-21-2006, 04:57 PM   #6
put 1mm spacers under the lower pivot blocks front and rear (both front and rear of the car and both front and rear blocks) this will get rid of your traction roll. or you could try taking some out the from under the inner camber link ballstud if there is any.
hope this helps
agower is offline   Reply With Quote
Old 04-21-2006, 05:50 PM   #7
jarrodh's Avatar
heres what i think hapens, if you lay the shocks down(top mounting screw twards the closest hole to the middle of the car) is gives the car mores grip, so the first thing i would do is straighten the shocks out(more twards the outermost hole) and lower the car,and also stiffen the shocks. but do only one of these adjustments at a time untill you find the appriote feeling,
the more you lay the front shocks down(top twards the middle of the car) the more steering response you will get, so if it turns in hard then straighen the front shocks out(top twards to outer most hole) and it will reduce the the sensetivity of entrance.
again only do one adjustment at a time until the desired feeeling is found
try this first, just use less traction wash,
hope this helps
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 04-21-2006, 06:24 PM   #8
anthony390's Avatar
Send a message via AIM to anthony390
i have a ? as well
ok what is roll center and do we want alot of it or very little of it?
does it deal with center of gravity?
also with the camber links
what happens when the two middle ones (inner left camber ball stud and inner right chamber ball stud) are lower?
PLEASE can some one fill me in
anthony390 is offline   Reply With Quote
Old 04-21-2006, 06:53 PM   #9
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I'd try more camber. Maybe your rim is digging into the carpet.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-21-2006, 07:02 PM   #10
Drewdc90's Avatar
Try making your track wider by putting 1 or 2mm shims between your wheel and hex.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 04-21-2006, 08:07 PM   #11
Superkarter's Avatar
lower the ride height
Superkarter is offline   Reply With Quote
Old 04-21-2006, 08:37 PM   #12
CarbonWorks's Avatar
Put a later of thin CA around the outer edge of the tire. From the rim all the way to the running surface. Use less dope. Try to mount the body as low as possible. You will be surprised how much of a difference this makes.
The roll center is the imaginary point at which the car pivots from side to side.
If you have a low roll center, you will increase side bite because more of the mass of the car will be above the roll center. I you raise the roll center, you will have less side bite because less mass will be above this point. The roll center works hand in hand with the center of mass(weight). If you were to strap a chunk of lead similar to the shape of a refrigerator into the bed of your pickup truck( standing up) and went around a sharp corner, the mass of the "refrigerator" would be above the the center of mass in the truck. This would generate a lot of side bite and possibly tip the truck over. If you put the same "refrigerator" laying down in the bed, you would generate a lot less side bite. So you can raise your roll center, or lower your center of weight. If you have anything mounted to the upper deck in the car, put it down on the main chassis.
By the way, the roll center is most easily controlled by the angle of the upper suspension links. It also has to do with the angle of the lower arms, but this is a little more difficult to change although it produces more change.
As a general rule, lowering the inner ballstud or raising the outer end of the link will raise the roll center at the end you are working on.
It is rather difficult to explain without reference drawings.
Some one else suggested putting a 1mm spacer above the arm mounts. As long as you keep your ride height consistant this will help out.
Lower all moveble mass on car, and if you are still rolling do what agower said earlier.
CarbonWorks is offline   Reply With Quote
Old 04-21-2006, 09:00 PM   #13
anthony390's Avatar
so center of gravity is used during the the movement or the act that is taken during the roll center's effect right
so basicly if you want to keep all 4 wheels on the ground, you would want low roll center?
Old 04-21-2006, 11:14 PM   #14
To keep all 4 wheels on the ground you want a low center of gravity(mass). If you cannot lower the center of gravity any more(moving weight lower on the car) then you raise the roll center. Changing the roll center is a mechanical adjustment, changing the center of gravity is a matter of moving weight around.
Just to repeat, add spacers above pivot blocks or lower inner ball stud height. These will both RAISE the roll center giving the car less roll in corners.
Remember to check ride height after changes.
Old 04-21-2006, 11:33 PM   #15
anthony390's Avatar
like keep all 4 wheels on the ground while cornering
SHOW STOPPING ATV,S TEAMCHRIST Other Items: For Sale/Trade or Wanted to Buy 0 07-30-2008 02:15 PM
Arlo Gilbert stopping by to say HI arlogilbert21 Chat Lounge 2 03-12-2008 09:53 PM
Stopping power!? Danie Nitro Off-Road 6 06-08-2007 08:03 AM
Stopping T maxx wizzydog88 Monster Trucks 2 01-29-2004 09:00 PM
Advice on traction rolling? Fred Perkins Electric On-Road 32 01-20-2004 03:08 PM
