Like Tree71Likes
New Yokomo BD12
Old 03-03-2023, 10:36 PM
kentech's Avatar
Default New Yokomo BD12
The new Yokomo BD12 has been revealed.
More: https://kentech.wordpress.com/2023/0...bd12-revealed/
kentech is offline
Old 03-04-2023, 05:47 PM
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Interesting
RKeasler is offline
Old 03-04-2023, 06:13 PM
Are spur gear changes on the BD11/BD12 as tedious as they appear to be?
blueflagger is offline
Old 03-04-2023, 10:31 PM
EDWARD2003's Avatar
I see it has some resemblance to that of the old OVA T4.
kentech and gwhiz like this.
EDWARD2003 is offline
Old 03-05-2023, 05:00 AM
Yup, BD7 through to BD11 at least. C-clip and 6 tiny shims. I guess they want us to keep buying xrays?
Not having to remove that stupid 1 piece upper deck will make it less enraging though.
But that should only be needed once every few months unless you're racing different series all the time.
Get a lot of spare c-hubs and steering blocks if you're going to race BD series on carpet with less than impeccable driving!
4k4m3 is offline
Old 03-05-2023, 07:10 AM
Best thing to do indoors is switch to standard plastic c hubs and steering arms rather than graphite. This helps a lot minimising breakages.
BKUK is offline
Old 03-05-2023, 01:02 PM
Beauty!
Daniil_D is offline
Old 03-06-2023, 02:08 PM
Ugh, I hope it’s not wildly different from the BD11. It doesn’t appear to be.
I bought a BD11 two weeks ago.
B-woo is offline
Old 03-06-2023, 05:34 PM
Regional Moderator
disaster999's Avatar
Most notable difference is the motor mount and top deck. Next is the C hub with holes to install the anti rub tab...the rest seems the same from the BD11.
disaster999 is offline
Old 03-07-2023, 01:37 AM
How about a simple/cheap upgrade kit then...
4k4m3 is offline
Old 03-07-2023, 03:05 AM
Probably could be done most expensive will be the chassis plate probably with new holes for the new motor mount.
Krapp said on one of his posts this wasn’t the final version and other options were being considered. The pictures don’t look like an official yokomo release.
BKUK is offline
Old 03-10-2023, 10:52 AM
Default Translation of BD12 Announcement
Ran the article through google translate. Not perfect but here what it returned:
NEW SEASOM
CLEVELS DEBUT
YOKOMO
MASTER SPEED BD12 (R#)
Price ● Undecided
I achieved both stability and speed.
Next-generation touring to fight the world!
Yokomo TEL 029-896-3888
Koita Koike = Text by Yuta Koike
Miyano Seiraku = Photographs by Masataka Miyano
Tsukuba radio-controlled park coverage cooperation
Yokomo's flagship touring car, BD series, which always runs at the top of the scene, is a full model change. "BD12 (tentative name)" was released, which injected with the know-how cultivated in races around the world.
According to Naoya Kitagawa Yokomo, who was in charge of the development, the new chassis will be divided.
Pursuing habit-free operability by optimizing the chassis roll by adopting the upper deck. With the installation of the newly developed center bulkhead integrated motor mount, the pitching style is enhanced than the one-piece upper deck, and the chassis flex can be finely adjusted with the number of fixed screws. In addition, the nervous movement that occurs from the central roll point in the split upper deck has also been successfully canceled with the installation of ATF (Active Top Deck Flex) adopted in BD11.
In addition, in the new chassis, the shaft position of the center shaft is commuted 4 mm from BD11, and the motor mounting position is moved to the front side by reducing the super gear to 90T. By lowering the center of gravity and bringing the two rotation moments closer together, the cornering speed at high speed is increased.
Front and rear weight balance
The MD layout made to 50:50 is the same as the previous model. The main chassis prepares both carbon and aluminum.
RACING FACTORY
The height can be adjusted for the new shape front hub carrier. The graphite front lower arm adopts a center bulkhead motor mount with excellent travel ability.
Equipped with a carbon body stepner. 0.5mm long in the corner ring. The stabilizer emphasizes the initial operation. The outer battery support does not come with the kit and prevents the tire from touching the inside of the body.
Combine the 12mm hard type for
I'm planning to release it as a brass option.
The shaft position of the center shaft is almost the same as the motor shaft. The bulkhead of the high rear upper deck has 0 rings. The rear lower arm is 1ml for BD11 with excellent traction.
Set to Sa. Inherited the ATF of the roller pin support with the spur gear smaller and the motor forward. Adopted rear shocker short. The aluminum rear hub is braking.
By doing so, the work that minimizes the effect of the rotation moment is changed to a low-mount type.
Combine the stable caster angle of 4 degrees
Even lower, optimize roll motion
A new chassis that lowered the morning of the center shaft and achieved an even lower center of gravity. The front and rear shock is also shorter than for BD11.
Full of "High Big Bore Shock" made by AXON
We are in the final test for release!
With a low center of gravity and a split upper deck, the handling performance is smooth, and you can maximize the grip of the tire without moving nervously even in the high speed range. Protociacy has already entered the final test.
I'm planning to debut in an international race in the Czech Republic in March.
end of article
kentech and maximebeauvais like this.
B-woo is offline
Old 03-31-2023, 04:39 AM
https://m.youtube.com/watch?v=6UCyv7nguIs&feature=youtu.be
BKUK is offline
Old 04-05-2023, 10:30 AM
kentech's Avatar
kentech is offline
Old 04-05-2023, 11:20 AM
Does the carbon version have different shocks than the aluminum? At least from the photos they look different. It could be a general update too.
Also when using the horizontal body posts the rear shocks mount on a horizontal piece of carbon fiber. Curious to see more photos, as this solution could allow for a lot of bending/flex of that "shock tower".
mr.rev is offline
