Old 04-20-2006, 03:25 PM   #1
brownpants's Avatar
Default Rayspeed Vs Protoform
I am really liking the look of the Rayspeed Accord body and am thinking of buying one, but first I would like to know how it compares to the likes of the Protoform shells with regards to handling etc.
Can anyone give advice on this?
Darren
brownpants is offline   Reply With Quote
Old 04-20-2006, 03:32 PM   #2
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
The rayspeed accord tends to push on corner entry, but then mid-corner and on exit it starts to rotate. It doesn't always feel "balanced" throughout a corner due to this, but it stays very flat and is easy to drive. However compared to Protoform bodies, it is a lot thinner, and therefore weaker in impacts. It is very popular though and you'd be lucky to find somewhere that has one in stock, as last time I heard CML were out of stock...
HTH
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 04-20-2006, 03:39 PM   #3
brownpants's Avatar
Cheers Ali,
Apart from the strength issue does it hold its own against the protoforms?
Darren
Old 04-20-2006, 03:51 PM   #4
nemisis's Avatar
well your running an Mi2 Ec rite i found the the protoform nemisis body handeled quiet well it was ver well balanced and held the corders very well it gave the read end of the car quitea lot of grip maybe due to the rear spoiler being so big and the roofline of the shell being so low but i woyuld def recomend it very nice shell
nemisis is offline   Reply With Quote
Old 04-20-2006, 03:55 PM   #5
dstyles's Avatar
it's pretty similar to the Ride TSX & you can read about it here:
http://www.rctech.net/forum/showthre...ht=ride+accord
dstyles is offline   Reply With Quote
Old 04-20-2006, 04:22 PM   #6
brownpants's Avatar
Cheers that Ride shell looks very nice. Only trouble is its not legal here in the Uk, whereas the Rayspeed one is.
Thanks again
Darren
Old 04-20-2006, 04:26 PM   #7
brownpants's Avatar
No I've got the Mi2 not the EC.
The only reason I want to know if it handles the same as the Protoform shells is because I would like to have a shell that is'nt the same as everyone else, but if it is doe'nt handle as well as the others then I will stick with the Protoform.
Darren
Old 04-20-2006, 04:34 PM   #8
nemisis's Avatar
thats even better then i used to run an mi2 before i went to the ec and i can safley say that i wouldnt try anyother shell on it two or three others members have got the an mi2 and they are all using the nemisis shell i did change once on it tried a strtus but soon switched bck to the nemisis give a go
Old 04-20-2006, 09:23 PM   #9
J.Filipow's Avatar
Trader Rating: 15 (100%+)
dstyles...nice avatar! It's almost as good as another bootleg Andre sticker I have seen that features Flav and the fact he has '...too, too, too much POSSE.'
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-23-2006, 11:37 AM   #10
Skiddins's Avatar
Originally Posted by brownpants
Cheers Ali,
Darren
The other thing with the Rayspeeds is the fact that the paint doesn't seem to stick to them very well.
Make sure you sand the inside with 2000 grit paper before washing and painting.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-25-2006, 11:03 AM   #11
dtam's Avatar
I also like the Rayspeed Accord as I also own one. Here in the States it's called an Acura TSX and this is my first paint job based on the http://www.realtimerl.com SCCA car. I even made a TSX badge on the trunk from the decals from an HPI RSX and S2000 and it has Tamiya 24mm grey porsche carrera wheels. I'm going to race it this weekend for the first time. I just like to be different and more realistic than all the Mazda 6s with white dish rims.
dtam is offline   Reply With Quote
Old 04-25-2006, 12:53 PM   #12
brownpants. just a quick question, are you runnning on asphalt(Tarmac), or carpet. If your running outdoors. Try the Mazda 6. work's great. the G6 which is a capet spec body, I tried it last time out. great handle. almost to much front grip.
anycase let us know what you got and show us a shot after you paint your new body.
cyrrus is offline   Reply With Quote
Old 04-25-2006, 01:28 PM   #13
stuey's Avatar
i've given up with the rayspeed body it works really well but they don't last very long costing a fortune going to stick to the mazda 6 and stratus 2.0
stuey is offline   Reply With Quote
Old 04-25-2006, 01:54 PM   #14
AM03GT's Avatar
i see the HPI wing on dtams car...
my accessment after running mazda6 vs rayspeed accord back to back for 3-4 days...
the rayspeed steers into corners more aggressively than the mazda... its also a little less stable than a mazda6... however, if you put a larger wing on the rayspeed i.e. mazda6 wing, jconcepts touring wing, protoform molded wing... the car gets more stable and drives closer to a mazda6 while keeping its turn-in characteristics...
my overall conclusion was that with the stock wing cut to roar/ifmar spec the rear had less downforce than the mazda, putting more balance on the front end... with a larger wing it was better, but i still think the mazda6 is an overall better balanced body... wouldnt be against running a rayspeed again though on medium low grip asphalt, it does look better
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 04-25-2006, 04:15 PM   #15
Tsquare's Avatar
Nice paint job dtam, are you really going to race it?
Tsquare is offline   Reply With Quote
yokomo sd rayspeed hurley081182 R/C Items: For Sale/Trade 15 03-13-2006 10:30 PM
$750 Rayspeed for $.01!?!?!? Griffin R/C Items: For Sale/Trade 1 07-02-2004 08:35 AM
Rayspeed Conversion Kit M.Hess R/C Items: For Sale/Trade 10 06-14-2004 02:38 PM
Rayspeed Discharger Geek R/C Items: Wanted to Buy 1 01-21-2004 12:57 AM
Rayspeed sd. racenut123 R/C Items: For Sale/Trade 5 12-12-2003 02:47 PM
