Old 04-21-2006, 10:16 AM   #46
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
if the bit were oriented correctly according to the rotation direction of the comm, would either spin direction produce the same cutting results?
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 04-21-2006, 11:06 AM   #47
D_Ames's Avatar
Send a message via AIM to D_Ames
Originally Posted by wagonman72
D_AMES
The tip alignment tip is awesome. I have an old Twister lathe that I am going to use that trick on. Once again VERY cool!
No problem. Just don't try it with a diamond bit.
Everyone, Jack Smash is correct (thanks Jack). I forgot the comm lathes are inverted. The tip should be centered or HIGHER to the diameter of the comm. Just not too high.
Sorry for the confusion.
D_Ames is offline   Reply With Quote
Old 04-21-2006, 11:10 AM   #48
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
No problem Oh wait.. im not Jack Smash
OUT
Keith Billanti is offline   Reply With Quote
Old 04-21-2006, 11:18 AM   #49
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Originally Posted by mafiaracers
But....you are using a "diamond" bit....I'm talking about getting maximum life out of a "carbide" bit.
13 years is still pretty sweet though...
And I was replying to a post that asked about the max life out of a "diamond" bit...
-James
JamesArluck is offline   Reply With Quote
Old 04-21-2006, 11:46 AM   #50
geeunit1014's Avatar
well....then moving to the topic of lathe speed.....if I'm using cells to run the slave motor, how many would be best? 2-3-4? at the moment I'm using 4. Should I take it down a cell?
it also depends on the slave motor. some people us a 55t, and some use an old stock or a silvercan, which would require diffrent voltages for the same speed
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-21-2006, 12:10 PM   #51
Default ^^^^^^^^^^^^^
I'm using a 55t....not silver can.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 04-21-2006, 12:31 PM   #52
I think last time I looked at an industrial supply site I found brand new sharp carbide bits for something like $5 each. Hard to beat!
Ken's Tools, Riverside, CA -- $3.25 left, right, or center cut. They also sell blanks so you can shape your own...
Dodgersfan is offline   Reply With Quote
Old 04-21-2006, 12:45 PM   #53
rc-zombies's Avatar
asuming you've got a 55 turn slave....how many volts or cells would be best?
I have a 55 turn on my lathe and run it direct from the 12v power supply.
Old 04-21-2006, 01:04 PM   #54
pheyhoe's Avatar
R/C Tech Charter Subscriber
Somebody mentioned about chipped bits. I am not familiar with the bit of a comm lathe but on a normal lathe the bit is shaped for different materials or how much material you intend on taking off in one pass. It is also shaped to direct the swarf.
When i chip a bit on a normal lathe and make a pass it will tend to leave drag marks on the workpeice. Its as if the tip is heating up too much. But its certainly no where near as clean a cut as a new unchipped bit. Whether this is the same on comm lathe bits i dont know..
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-21-2006, 01:08 PM   #55
hurley081182's Avatar
Send a message via AIM to hurley081182 Send a message via Yahoo to hurley081182
Alright, check this out...I am living at a college and we have a pretty big physics department. In the physics building, we've got a rather extenisve machine shop complete with pretty much any tool you could possibly imagine for making anything your heart could desire.
ANYWAY, I took my carbide comm cutting bits there today to talk to one of the physics professors about sharpening them. So, he got all excited when I showed him the bits and then the comm lathe itself and then I cut the comm once so he could understand what exactly it was supposed to do.
Long story short, we took the bits and put them under a major league microscope and looked at the tips and he said that they were just fine. This is after about 20 cuts. I told him that these bits should only last around 5-20 cuts then they become dull and need to be either replaced or resharpened.
He looked at me like I was freakin crazy! "20 cuts!?" "on a carbide bit!?" He said that with carbide, and proper use, cutting technique, and assuming you're only cutting comms.....QUOTE!!! "there's no reason you shouldn't get atleast 1000 cuts before re-sharpening." UNQUOTE!!! I told him he was crazy, but he was absolutely serious in his remark.
He talked about using a special cutting fluid on the comm/bit during cutting to keep the action well lubricated and cool and that with that, there's no reason you shouldn't get atleast ONE THOUSAND cuts before re-sharpening. so now, he wants to buy up a bunch of motors and one brand new carbide bit and use my lathe to cut motors until with the truth of a microscope reveals that the bit is no longer capeable of producing a proper cut.
1000 cuts with a carbide bit....what do you think about that.....
so can u cut carbon fiber chassis there at your college?
Old School Stampede=FUN
hurley081182 is offline   Reply With Quote
Old 04-21-2006, 01:18 PM   #56
if I knew how to make the program on the 2d machine...I don't see why not...
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 04-21-2006, 04:16 PM   #57
D_Ames's Avatar
Some useful information
Old 04-21-2006, 04:39 PM   #58
interresting...
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 04-21-2006, 05:20 PM   #59
XrayFK's Avatar
I have AutoCad or Solidworks if you need something drawn up.
XrayFK is offline   Reply With Quote
Old 04-21-2006, 05:52 PM   #60
sweet man! I'll let keep that in mind!
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
R/C VA. AMBrc Food Hobby Shop This Track Is Not For The Weak! R-C PRO RACING Track Locator Forum 23 03-12-2012 04:06 PM
IM FULL NOW, NO MORE FOOD!!! sirio man Chat Lounge 1 05-12-2007 05:40 PM
FAST FOOD axel Chat Lounge 20 07-24-2005 10:08 PM
Tips for food redsand Indonesia Racing 38 01-18-2002 08:26 AM
