Old 04-19-2006, 06:12 PM   #1
mcrcracer's Avatar
Arrow Brushless or Brushed?
I am looking at getting into the modefied class, and I was wondering which is better: brushed or brushless?
The thing with brushed is you can rebuild your motors whenever you want, but you have to mess with gearing a lot.
But, with a brushless, you don't have do rebuild the motor frequntly?
Also, which one is faster?
mcrcracer is offline   Reply With Quote
Old 04-19-2006, 07:26 PM   #2
I don't know much about brushed. i do have a brushless NOVAK GTB5.5 it's fast as a 8T or 9T brushed. mine is new my budy has over 100 battery packs no need to rebuild motor. Go brushless you will love it!!!!!!!!
kahuna2793 is offline   Reply With Quote
Old 04-19-2006, 08:04 PM   #3
Go brushless, you will love it. Maintainance free
Go_Tamiya is offline   Reply With Quote
Old 04-19-2006, 08:06 PM   #4
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
mcrc, definitely go with brushless. You'll have longer runtimes, more consistant power throughout the run and virtually no maintenance. While everybody else is cutting comms and breaking in brushes between heats, you'll be trying to better your score on tetris on your cellphone...
Tony
RcCzarOfOld is offline   Reply With Quote
Old 04-19-2006, 11:18 PM   #5
Drewdc90's Avatar
Yeah brushless is the way to go in mod. Now the 4.5 is out, there will be no need to run a brushed motor.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 04-19-2006, 11:42 PM   #6
syndr0me's Avatar
Trader Rating: 32 (100%+)
Whoa, it's unanimous. Brushed motors are poop. :-)
syndr0me is offline   Reply With Quote
Old 04-20-2006, 08:32 AM   #7
Send a message via AIM to Deznuts05
I too am on the fence on this however I've been told:
BL system
Pros:
Zero maintenance
More efficient
Cons:
Prone to go poof
Lost of tune-ability
Equivalent to a 9 or 8 t motor however a with the tune-ability you can make a brushed motor spin faster
Brushed
Pros:
Tune-ability can make a 9t spin like a 8t
More torque or better power band
Cons:
Maintenance
Comm life
Hope I didn't miss anything out
Deznuts05 is offline   Reply With Quote
Old 04-20-2006, 08:40 AM   #8
In mod, it's hard to argue against the benefits of brushless.
Personally, I'm a little soured on brushless as I've had/seen problems with both of the major sensored systems out there.
All I know is that if I were a factory driver running brushless at a race event, I'd darn sure have a backup system.
Stability (read: smoke and fire) aside, the "no maintenance" really is nice. Solder the beotch up once, and it's ready until it explodes. Which it just might do...
In all fairness, I've heard that LRP has worked the kinks out. I've seen quite a few GTBs smoke up on high end batteries though... not sure if that's been corrected.
Jason B is offline   Reply With Quote
Old 04-20-2006, 10:11 AM   #9
Tech Legend
Wild Cherry's Avatar
I`v been runing my Sphere & Neo sence it became available ...
Don`t have to tune , just to get the same speed the run before or get use to losing that tune up after a couple run`s (brush)
Don`t have to buy $12 XXX brush`s each race day (brush)
The Sphere & Neo is very reliable , I`v seen many of my fellow racer`s toast a brush motor with flames & smoke ... Happen all the time ....
Still has never happen with My Neo....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-20-2006, 10:39 AM   #10
Tsquare's Avatar
Good discussion and good replies by all, but has anyone noticed the different feel the brushless motors have vs the brushed. It is hard to describe, but the brushless motors feel more mechanical, where as the brushed motor feels more flexible and natural in it delivery of power and braking. I may not have enough time with my system, or maybe need to adjust my ESC. I currently have a Novak GTB / 5.5. If anyone has expirenced the same I would be interested to hear your comments, or if someone can give me setup suggestions to help my brushless feel more like my brushed motor, I would appreciate that too.
Tsquare is offline   Reply With Quote
Old 04-20-2006, 11:07 AM   #11
Tech Legend
brushless thottle is very linear in feel ...
Its way more betta cus you don`t have to adjust your stlye to the tune of your motor each run ..
same thottle feel run after run , which helps you alot..
Try getting that from a brush motor....
Not happening ... They change run to run , each time you cut the com , they change , each time you install new brush`s they change ,ect....
After a while you really begin to appreciate the brushless system so much, you will never go back ....
George W. Cherry
Old 04-20-2006, 12:08 PM   #12
The latest brushless systems, reliability aside, have the "brushed feel" down to the letter. The only thing to keep in mind is weight balance. Brushless components have VERY different weight and balance characteristics than brushed setups, which can be tricky since cars were developed with brushed systems in mind.
But strictly from a feel standpoint, they're great.
Old 04-20-2006, 03:48 PM   #13
As it was shown in this forum few thread back, LRP BL system is about 28-30 grams heavier than brushless sys wih QC2.
Besides that, i have to add around 50-60 grams when using brushed sys. It definitely is not so essential matter to do not go with brushed system
JanisK is offline   Reply With Quote
Old 04-21-2006, 12:18 AM   #14
Drewdc90's Avatar
One of the cons of brushless mention before is that they are equal to 8 to 9 turn isn't right. The 4.5 is at least equal to a 7 turn. The mod field in the last bigish meet I went had 7 out of 10 people in the A running brushless (mostly 4.5's), the brushless motor were actually the quickest motors down the straight. So the speed of brushless is not really a con.
Drew.
Old 04-21-2006, 01:16 AM   #15
between Brushless which one more powerful of these two,
any comparison between LMT5300+U-Force 75 and LRP BL?
Faiz is offline   Reply With Quote
WTB: Brushless/Brushed ESC hpiaddict R/C Items: Wanted to Buy 9 06-16-2008 01:08 AM
WTB Brushed/Brushless ESC GTB, MM Mooshu Beef R/C Items: Wanted to Buy 0 12-16-2007 01:49 PM
Brushless/Brushed ESC BADAZZPSD R/C Items: Wanted to Buy 2 12-15-2007 03:54 PM
13.5 Brushless vs. 27T brushed Speed D Electric On-Road 19 07-31-2007 08:46 PM
brushed or brushless? nekmiyevo2 Electric On-Road 61 11-07-2005 03:35 PM
