Like Tree105Likes
Tamiya MB-01
Old 01-31-2024, 09:13 PM
  #151
gigaplex's Avatar
Originally Posted by jdob
I am asking which (gear) diff/outdrives I need to use with the 53597 M03 Universals - if the stock ones will not work - as other users above have mentioned may be the case.
Any help is appreciated - Thanks!
Stock diff will work if you change the outdrives. Or you can change to a different oil sealed diff. There's quite a few options.
jdob likes this.
gigaplex is offline
Old 02-01-2024, 12:00 AM
  #152
Assuming that the MB-01 diff are the same as TT-02, #19804237 outdrives used in TT-02S should work. Alternatively, you can get an XV-02 sealed diff, which comes with metal outdrives.
EDIT: Tamiya parts matching list suggests using #54477 outdrives. By the looks, it's just a reinforced variant of the #19804237.
jdob likes this.
Papi is offline
Old 04-08-2024, 11:27 AM
  #153
I see a couple new bodies coming:
https://www.tamiyausa.com/shop/110-m...ett-gte/mb-01/
https://www.tamiyausa.com/shop/110-m...roen-ds/mb-01/
leadfootedfool is offline
Old 04-09-2024, 05:10 AM
  #154
Originally Posted by leadfootedfool
As someone whos driven an old Citreon, you really have to recreate their ultra floaty suspension to get the full effect. Otherwise it just doesn't look authentic in action.
leadfootedfool likes this.
Revolter22 is offline
Old 04-09-2024, 05:16 AM
  #155
That’s what was so great about the M01 and M02. They were goofy and fun to drive and bobbed and torque steered and had a true scale speed and handling to them.
I finally broke down and ordered the prepainted abarth, we’ll see if it’s as fun as the old ones.
MonkeyCmonkeyDo likes this.
Old 04-22-2024, 12:50 PM
  #156
Core Creations's Avatar
Trader Rating: 110 (100%+)
I had a chance to build a kit this last week. I did just a couple hop up and the car is not bad at all on carpet. I added a sealed rear diff, aluminum suspension balls, CVA shocks and a little bling. This car is at least as good ast the 03-06 generation of minis. Lots of slop, but who cares. They are a blast to drive! IMO, this kit gets back to what makes Tamiya kits fun!
My only real compliants are the steering limiters (quick dremel fix) and lack of other options. If you’re on the fence…pull the trigger. Super fun kit!
Core Creations is offline
Old 04-22-2024, 02:26 PM
  #157
gigaplex's Avatar
Dremel isn't an option under a lot of rulesets.
gigaplex is offline
Old 04-22-2024, 03:01 PM
  #158
There isn’t a specific class for this here so it’s all good. If there is ever to be a TCS specific class, they’ll have to address it.
Old 04-22-2024, 07:12 PM
  #159
MonkeyCmonkeyDo's Avatar
I dig the crx body. Good choice.
d
MonkeyCmonkeyDo is offline
Old 05-11-2024, 08:37 PM
  #160
Hello, I am new to the forum and to Tamiya RC Cars. I usually run TLR or Associated. I purchased a MB-01 for my nephew, and we run it at a local track that has an M-Class. It is the Giulia Sprint GTA Club (MB-01)
The issue as soon as he touches a board, the pivot ball (P7) pops out of the upper arm (M2). The assembly is Page 7 of the build manual for the car.
It is very unreliable to run at a race without the ball popping out. I guess I can try to purchase new arms and pivot balls, but it seems this a weak portion of the car. Someone at the track had a M-07 and M-06. Is there any way to adapt the suspension from the other M cars to the MB-01? Or, is there any aftermarket parts that will work to make this more reliable?
Hoping someone can help.
TurboCooler is offline
Old 05-11-2024, 10:42 PM
  #161
gigaplex's Avatar
No the parts aren't compatible between the MB-01 and the other cars. What are the rules for the class you run in? Tamiya mini classes often have restrictive rulesets regarding aftermarket parts.
You might be able to run a wide washer in between the screw and the ball to try to capture it, though I haven't tried that yet.
gigaplex is offline
Old 05-12-2024, 01:18 PM
  #162
You can either run a wide washer on each pivot ball, or order two sets of metal "low friction" pivot balls, part no. 54559, or something in-between. I did that on my MB01 and they quit popping out. No new arms necessary.
I hate to say it, but the MB01 isnt quite as robust as the old M05/M06 models. It doesn't share any parts with the M07/M08 nor the previous models.
gigaplex likes this.
Old 06-01-2024, 04:29 PM
  #163
gigaplex's Avatar
I finally took my one for a spin about 3 weeks ago (in FWD configuration) and it wasn't as awful as I was expecting. It did tend to bind up and stall mid corner a bit with full steering lock, unsure if it's the front wheels fighting each other with the inverse Ackerman or if it's the dog bones. But I did run into an issue with the stock servo saver. It has a stub that sticks down and hits the body of the servo, further limiting the steering travel in one direction. It looks intentional, I can't see a reason for the stub existing. I've looked into replacing it with something else, but the 51000 saver will significantly move the ball stud vertically which might bind the short link. The Tamiya part list for the car suggests the 51000 saver, seems like Tamiya really haven't paid any attention to this at all.
Car was mostly stock other than bearings, oil dampers and alloy wheel hexes.
angrymelon and Revolter22 like this.
gigaplex is offline
Old 06-06-2024, 07:58 PM
  #164
I IThe Tamiya part list for the car suggests the 51000 saver, seems like Tamiya really haven't paid any attention to this at all.
I'm pretty certain that Tamiya spent most of their design resources on the transmission and wheelbase adjustment, then added in everything else as an afterthought.
Old 06-06-2024, 08:15 PM
  #165
gigaplex's Avatar
And still they came up with that driveshaft 🤔
gigaplex is offline
