Old 07-17-2006, 04:07 PM   #91
Originally Posted by rcnewb2004
How do you add tweak to a car?
Pardon my newbishness... but what is torque steer? I know it exists in all shaft cars... but that's it?
Torque steer is basically the result of what's called "Conservation of angular momentum". Letís pretend that you are looking from the back of the car. The shaft of the motor is inline with the car. Now, imagine that motor is accelerating, turning counterclockwise. At this instant, the constant value (inertia) stays the same, but since the motor is speeding up, the angular momentum of the system is getting higher (the direction of the moment is point to the back of the car). Due to the physics law of conservation of angular momentum, in order to keep the angular momentum conservative, the entire system will react to the changing in the momentum by rotate the entire car clockwise (the moment is point to the front of the car) to keep the angular momentum conservative. The moment or torque will exert force on the right side of the chassis downward.
A good example would be if you take your car off the ground, and look from the right side of the car. Now pull the trigger, your wheels will be spinning clockwise (the moment is point to the left of the car), but the entire car will be turning counterclockwise to react to the moment. The reason that your car is not trying to spin as fast as the wheels is because the car has much larger inertia, so it takes less angular velocity to achieve the same angular momentum.
So, on a shaft driven car, if you take the car off the ground, and pull the trigger, not only the front of the car will lift up, but itíll also try to lean on one side (depends the direction of the motor that is turning). It may be hard to feel just by holding the car, but the force is enough to cause your car pull on one side on the track.
thegreatimpulse is offline   Reply With Quote
Old 07-17-2006, 04:10 PM   #92
chubbspeterson's Avatar
There is a shaft car out there that feels like a belt car and will be in an A Main this year. I will personaly guarantee it.....
Yokomo SD Tommy Kraimer edition.
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 07-17-2006, 04:31 PM   #93
Chris08527's Avatar
Trader Rating: 16 (100%+)
i think people can talk all they want about g-force this a torque steer that
but what it comes down to is that MOST (not all) of the top drivers out there are driving belts
and it is that simple . . .
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 07-17-2006, 04:55 PM   #94
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by chubbspeterson
Yokomo SD Tommy Kraimer Edition.
yup, i watched mike wise run that car at trackside this weekend for the summer sizzler. he had hot lap over all the factory stock guys from corally, xray, and schumacher. it was impressive to say the least.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-18-2006, 06:24 PM   #95
Is there a website where I can who is winning all the big races? All I do now is see them in the mags here and there. I know Xray seems to be winning lately, but weren't PRO4's winning a bunch early in the year?
porschejim911 is offline   Reply With Quote
Old 07-18-2006, 06:25 PM   #96
your at the right place rc tech always has coverage for national, worlds, regional and everything in between
Mike Demone
Old 07-19-2006, 12:58 AM   #97
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Got pics or links for this?
YR4Dude is offline   Reply With Quote
Old 07-19-2006, 04:47 AM   #98
hummm, pic's you say this is the only one I could find. Tommy is out of the UK so he's hard to get a hold of.
This car just took 3d at the summer sizzler a trackside, the only yokomo in the feild. and the only shaft car in the main.
Mike Demone
Old 07-19-2006, 04:53 AM   #99
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Sobottka also runs a shaft car he took second
wallstreet is offline   Reply With Quote
Old 07-19-2006, 05:01 AM   #100
wallstreet's Avatar
Who is tommy kraimer ?
Old 07-19-2006, 07:00 AM   #101
seaball's Avatar
http://www.pdubracing.com/schumacher...e/gallery2.htm
three quarters of the way down is another pic of the sd-tke car.
Old 07-19-2006, 01:49 PM   #102
nice work wallstreet...... Tommy Kraimer is a legend
nuff said.
Mike Demone
Old 07-19-2006, 04:31 PM   #103
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Wise....you forget the SRD shaft tourer took second....haha. You can try to catch me at Vegas or Cleveland buddy!
Wise and I are both running shaft tourers that are as smooth as belt cars. We have our own custom ride which we are producing, the SRD. Wise is running the Yok as previously stated.
Last year I have proven that shafts are not behind belts in performance or for efficiency. I made A's in stock and 19t at Vegas and Cleveland. These were two totally different beats as far as traction and layouts and the shaft car had no problem keeping up with belts. Wise will agree with me that shafts are still fast...if not faster. The hindering performance of the TC4 and breaking of gears in the Evo 4 has turned many people back to belts. With so many wins from Corally and Xray...and not seeing a win from Associated, how could people not be running belts? What wins on Sunday...sells on Monday. TC3's are still fast...I could prove it.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-19-2006, 05:01 PM   #104
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default pics please...
i have to see that one....SRD...
pics please.....
i have to say the yok LCG is tops...but not made for carpet..
why doesn't Yokomo produce a stiff version of the car.....Yes i know the U.S. carpet racers are a small group for Yokomo...but darn we spend so much money..give us what we WANT...
olhipster1 is offline   Reply With Quote
Old 07-19-2006, 07:22 PM   #105
wallstreet's Avatar
Both Wise and Sobottka had there cars dialed at the sizzler. they both looked awsome.
Single shaft vs split shaft/slipper 1/18th-Vendetta/RC18 vs MLST/Half 8 imjonah Micro and Mini Scales 5 08-24-2008 01:38 PM
1/10 Pan tourers hardrider R/C Items: Wanted to Buy 5 11-01-2007 05:32 PM
pro tourers bradnewman_24 Nitro On-Road 3 11-19-2005 11:35 PM
Looking for 1/10 EP/GP tourers lee82gx R/C Items: Wanted to Buy 2 12-13-2002 07:06 PM
Let's See those tourers! NitroLuver Nitro On-Road 9 12-06-2001 09:13 AM
