Old 04-18-2006, 12:47 PM   #16
Originally Posted by trf racer
i cannot tell what 1mm does on ur radio.
if u push the throttle so the car takes up slack in the transiomission ie it goes to go but it cant,this is normal,bc the armature has to produce power to get over the cogging effect which is caused by the magnets this is normal.
motors perform best when they rev,running your car at low speeds will not tell you anything about how the car or motor are working,you could burn the motor out by doing this, what does the car/motor run like at high speeds .
what your trying to do is like trying to pull away from a standstill start in 4th gear,the motor cannot produce enuff power at little throttle.run your car normal speeds and se what it does.
o right . at the mo (answering the question with the around it) i havent yet tested the top speed , i only got it running today and its raining
BeastFromDaEast is offline   Reply With Quote
Old 04-18-2006, 12:48 PM   #17
when my car runs as fast as i can get it in a 10ft kitchen its smooth and fine. when it gets to snails pase after just costing for a while it stops harshly, is that wrong ?
Old 04-18-2006, 01:02 PM   #18
after it stops harshly does it pull when u apply more power.
if it doe nothing wrong if not ur speedo maybe using the thermal cut off,how hot is the speedo getting
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 04-18-2006, 01:13 PM   #19
dodo's Avatar
Send a message via Yahoo to dodo
motors have different characteristics, for example, i have an epic shock motor which can be turned easily and also a spashett edition peak vantage motor which is harder to turn. it's normal.
from snail pace to immediate stop, it's normal, it's the motor that's holding the car from rolling, because of the reason above (magnetic etc and as well ur gear ratio)
the important thing is ur drivetrain, test it on a track and see whether you have problem in gaining speed or deceleration.
i hope you are not comparing these cars to gas powered cars, it's different in GP where the clutch will not engage if the engine is not powered or throttled.
dodo is offline   Reply With Quote
Old 04-18-2006, 01:18 PM   #20
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Make sure the motor mounting screws aren't too long........
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-18-2006, 01:21 PM   #21
PitCrew's Avatar
I don't think there is anything wrong with your car, speedo, or motor.
Why do you want to drive it at a snails pace anyway???
PitCrew is offline   Reply With Quote
Old 04-18-2006, 01:35 PM   #22
i agree,theres nothing wrong with ur car that we can undertsand so just race and enjoy it
also do not run in small confined spaces,you are not running at high enugh speed to cool electronics,you will damge the motor and other things if not carefull.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 04-18-2006, 01:35 PM   #23
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
this is really good stuff.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 04-18-2006, 02:02 PM   #24
the speedo is not hot at all. what do u mean by pull ?
Old 04-18-2006, 02:03 PM   #25
i dont . read my post more closly
Old 04-18-2006, 02:11 PM   #26
i.a.s's Avatar
funny
i.a.s is offline   Reply With Quote
Old 04-18-2006, 02:20 PM   #27
Originally Posted by i.a.s
funny
that is yea , lol jokes on him/her
Old 04-18-2006, 02:22 PM   #28
did you check your transmiter settings? throttle, speed, etc.
MOJO is offline   Reply With Quote
Old 04-18-2006, 02:25 PM   #29
i would go outside with it but its not waterproof
Old 04-18-2006, 02:26 PM   #30
LOL
FS: Too much to put in the title!! aussiebuddha Australia For Sale/Trade 1 01-31-2008 09:45 PM
title scoobydew Rookie Zone 2 07-25-2007 08:37 AM
thread title removed andy_666 Chat Lounge 12 04-13-2006 01:06 AM
NSW State Title Wynnum_Racer Australian Racing 3 02-13-2005 12:35 AM
edited title Nrctc3 Electric On-Road 2 11-18-2004 05:39 PM
