Old 04-16-2006, 09:12 PM   #1
nikkon99's Avatar
Default proper gearing
I was wondering if anyone could tell me how to properly gear my car..currently i am running an 88 tooth spur gear and an 18 tooth pinion with a high rpm motor the car runs well but the motor gets soo hot and i feel that if i go any smaller i will lose speed.
nikkon99 is offline   Reply With Quote
Old 04-16-2006, 09:52 PM   #2
T1Raycer's Avatar
which car?
what motor???
how big is the track??
thecnical or open???
have to know those thing to say a normal gearing!!
Later!
T1Raycer is offline   Reply With Quote
Old 04-16-2006, 09:55 PM   #3
nikkon99's Avatar
its a losi xxxs with a team scream atlas based motor the track is pretty open for the most part..a few technical sections and its about 100' long and maybe 40' wide
Old 04-16-2006, 10:01 PM   #4
T1Raycer's Avatar
on rubber or foam??
Old 04-16-2006, 10:04 PM   #5
nikkon99's Avatar
rubber on asphault
Old 04-16-2006, 10:13 PM   #6
T1Raycer's Avatar
your setup at the moment is
team losi xxx-s whit 88 spur gear and 18 pinion whit 63mm tire rubbber so your rollout is 22.1 !! its so undergear so thats why your motor is so hot and dont run at his full performance!!
here we run the atlas at 31-33mm of rollout so!! you need gear them higher!!
i will suggest starting whit a 25 of pinion (7 teeth difference )
25 pinion is 30.075 mm
26 pinio is 31.954 mm
27 pinion is 33.183
starts whit a 25 pinion!!
Later!!!
Old 04-16-2006, 10:15 PM   #7
nikkon99's Avatar
really? i did run a 25 and i cooked the first motor so the guy i bought it off of gave me another one and he said because it was such a high rpm motor i had to gear it way lower than others
Old 04-16-2006, 10:21 PM   #8
T1Raycer's Avatar
im sure you ahve to run them at 31-32 of rollout my friend here run one and he gearing them at 32 and the motor after 5 min is ok and he's fast!! im 99.9 % sure you have to gear them at 32!! i run a cameleon that have a lot of rpm amd more rom than atlas and i run like 27-28 mm of roll out!!!
Old 04-16-2006, 10:23 PM   #9
nikkon99's Avatar
well ill have to give it a try thanks for your help
Old 04-16-2006, 10:25 PM   #10
T1Raycer's Avatar
what the color of you comm after a day at 22 of rollout??
Old 04-16-2006, 10:27 PM   #11
nikkon99's Avatar
u know i havent looked recently
Old 04-16-2006, 10:30 PM   #12
T1Raycer's Avatar
hum k take a lot you need to clean it after each run and if your comm is like red or purple/blue the motor has overheating and also check your brush
Later!!!
Old 04-16-2006, 10:31 PM   #13
J@UNE's Avatar
Best thing would be to get the gearing ratio of the other fast guys at your track. Like T1Racer said the C2 have more RPM than the blue atlas, I don't concider that motor as a high rpm motor.
From my experience, It need to be geared like the peak dynasty/orion element, or a tooth lower than a quad mag. I run my blue atlas at 32 of rollout on carpet and our track is around 85*35
Hope this help.
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 04-16-2006, 10:36 PM   #14
T1Raycer's Avatar
Niko
Jaune is th guy im talikng about!! hes running 32 whit the blue can so 22 was very unergeared!! cut the comm put some new brush and try it at 32 like Mr.Jaune said!!
Have fun
Later!!
proper gearing meatums Electric Off-Road 3 08-01-2008 04:36 PM
proper gearing @ WLRC cyclone speed Electric On-Road 3 06-18-2008 12:30 AM
Proper Way ?? Armedforces Radio and Electronics 5 04-14-2008 03:15 PM
Proper Discharging scoobydo Electric On-Road 16 03-19-2005 11:53 PM
proper charging zachzachz Rookie Zone 3 07-16-2003 08:49 PM
