Old 12-31-2002, 09:23 PM   #31
racer's Avatar
to thoroughly clean out the bearings, do you have to open up both sides (shields) of the bearing?
i'm afraid it may fall apart. any pointers will be appreciated.
Thanks!
racer is offline   Reply With Quote
Old 12-31-2002, 09:39 PM   #32
popsracer's Avatar
Default bearings may fall apart
racer;
Some people do some people don't. Buy the RPM bearing blaster, it works really well and will force the cleaner and lube through the seals/shields, no disassembly nesessary.
popsracer is offline   Reply With Quote
Old 01-02-2003, 05:00 AM   #33
I use Duckhams 0w40, initially the viscosity of the oil is too high but after 30 seconds, there is enough heat that the oil becomes nice and runny.
just my 2 pence worth.
sanj
schumacher is offline   Reply With Quote
Old 01-02-2003, 09:35 AM   #34
popsracer's Avatar
Default do you have to open up both sides (shields) of the bearing?
racer;
A couple of things. In ALL of my Nitro Cars, I always use Rubber Sealed bearing to keep the Dirt out. In my Electric Car I was told to remove the seals/shield for less drag. Problem is now they are way too high maintenance and I really didn't notice any improvement by removing the seals. I'm going to replace them with Teflon sealed bearings for a good happy medium of drag and maintenance.
I also tried some Mobil 1 for bearing oil, but I feel it is too heavy. Going to buy some Trinity Royal oil as most of you guys seem to like it.
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 10:34 PM
Ceramic Bearing VS Normal Bearing MRX_joe21 Nitro On-Road 25 11-19-2005 11:09 PM
One way bearing gone...again! silacomalley Monster Trucks 6 10-03-2005 05:07 AM
f/t: new one way bearing? arawak420 R/C Items: For Sale/Trade 0 02-25-2005 08:55 PM
Bearing Oil? trf415 Electric On-Road 20 04-02-2004 05:58 PM
