Old 12-24-2002, 12:52 PM   #16
gacjr0's Avatar
Trader Rating: 15 (100%+)
Try Mobil 1 synthetic motor oil, $5 a quart. Keep a bottle in your garage, or just pour some in your oil bottle/dropper at each oil change.
gacjr0 is offline   Reply With Quote
Old 12-24-2002, 01:12 PM   #17
Mobil 1 is an excellent bushing lubricant but wasn't designed to lube ball bearings. The viscosity of Mobil 1 is much higher than MIL-L-6085C & viscosity = drag.
BTW: Trinity's bushing oil is just repackaged Mobil 1
dalem is offline   Reply With Quote
Old 12-24-2002, 01:56 PM   #18
Rob68's Avatar
I also use Zubak's. I have had good luck with Royal Oil as well, but I think the Zubak's works even better. Its some killer lube.
Rob68 is offline   Reply With Quote
Old 12-24-2002, 03:48 PM   #19
JimmyMac's Avatar
Niftech Micro Bearing Oil seems to work pretty good too. But it's petrolium based... Only $5.
JimmyMac is offline   Reply With Quote
Old 12-24-2002, 04:22 PM   #20
Suspended
Thumbs up Cheap OIL
Just use automatic trans fluid, about a buck a quart at kragen.
Mr R/C is offline   Reply With Quote
Old 12-24-2002, 05:35 PM   #21
popsracer's Avatar
Default The BEST bearing oil.
Anyone tried Prolong for bearing lube. How is it with attracting dust. Tranny fluid is terrible with dust. Lot of guys I know use the 5-15wt Mobile-1 oil.
Anyone running their bearing without the shields/seals? Did you notice any advantage?
Thanks,
popsracer is offline   Reply With Quote
Old 12-24-2002, 08:48 PM   #22
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: Re: Re: Re: Best bearing oil?
Originally posted by dalem
MIL-L-6085D
Excellent. Thank U very much!
dtm is offline   Reply With Quote
Old 12-24-2002, 08:51 PM   #23
dtm
dtm's Avatar
Default Re: The BEST bearing oil.
Originally posted by popsracer
.......Anyone running their bearing without the shields/seals? Did you notice any advantage?
Thanks,
Yes! most definately things free up a lot. but just remove the shields on the inside of the hub bearings to keep the dirt out. Only problem is that they become quite high maintenance. I take my bearings out about every 2 days of running and lube once for each day of running.
Old 12-24-2002, 09:38 PM   #24
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Best bearing oil?
can you fill me some? i will give you an empty O'donnel one gallon empty bottle!
Manticore is offline   Reply With Quote
Old 12-24-2002, 10:19 PM   #25
Moderator
Speedo's Avatar
Triflow
Speedo is offline   Reply With Quote
Old 12-24-2002, 10:41 PM   #26
The orion oil sucks. Trinity Royal oil is the best.
rcpilot is offline   Reply With Quote
Old 12-24-2002, 11:42 PM   #27
dtm
dtm's Avatar
Default Re: Re: Re: Re: Re: Re: Best bearing oil?
haha....are you going to "wash" your cars with it!!
Old 12-25-2002, 09:51 AM   #28
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: Re: The BEST bearing oil.
I usually end up blasting and re-lubing about ever other race. I'm using the Team1 bearing lube.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-25-2002, 06:55 PM   #29
racer's Avatar
has anyone used the comm/bearing lube from Peak performance?
Old 12-25-2002, 07:39 PM   #30
rccarracer's Avatar
I've been using the Fantom Bearing oil with great success.
Only tried the Peak stuff once, (borrowed it from a friend when I run out of the Fantom lube) and seemed to work just as well as the Fantom stuff.
Still use Fantom though, as it is what my LHS stocks 95% of the time.
rccarracer is offline   Reply With Quote
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 10:34 PM
Ceramic Bearing VS Normal Bearing MRX_joe21 Nitro On-Road 25 11-19-2005 11:09 PM
One way bearing gone...again! silacomalley Monster Trucks 6 10-03-2005 05:07 AM
f/t: new one way bearing? arawak420 R/C Items: For Sale/Trade 0 02-25-2005 08:55 PM
Bearing Oil? trf415 Electric On-Road 20 04-02-2004 05:58 PM
