Like Tree223Likes
Tamiya TB Evo 8
Old 02-01-2023, 12:22 PM
  #121
Originally Posted by zuqbu
Forget what I said, I had another couple of runs yesterday and it started traction rolling again. The sway bar helped a bit (and yes, I think the kit standard is 1.1mm) but I guess it was more the freshly applied side wall glue than anything else. As I progressed through the day the problem returned. I remember what you said and I changed the front suspension inserts (or rather switched the N2 around to go from D to F) and that made it better – although in my last run it started rolling again (much less this time though) but that could be the side walls requiring some glue again. Other than that the car feels amazing and I could improve on my best lap.
Brill, at least that's progress then. I havent rolled once since I went to f blocks at the front, but our carpet is inly medoum grip. But it's still got so much steering, I'm running around 20% less servo travel than I did with my 419xr and still have more steering.
You could try changing the droop a touch, maybe 6 front and 5 rear, appose to the usual 5.5 front 4.5 rear
hipwell is offline
Old 02-01-2023, 08:25 PM
  #122
Originally Posted by Robbob
No - they all have their own unique spin on things.
One could say its a clone of a TC3 and the veteran racers could go as far to even say the TC3 was a clone on the Tenth Technology lol.
Similar but not the same kind of thing.
Tenth Technology.... that's going back a ways!
Sofa King is offline
Old 02-02-2023, 11:12 AM
  #123
I'm tempted to rebuild mine in the rear motor config, I think that might take away some of the front end bite as itl be a bit more rear balanced
hipwell is offline
Old 02-02-2023, 11:50 PM
  #124
zuqbu's Avatar
I am currently running 5.4 in front and 4.8 in rear. But shouldn't less weight transfer be more favorable in this case?
I wanted to try that out sometime as well. I just spent so much time on the electronics layout and soldering that I feel committed to the front motor config. If you do end up switching things around please report back
zuqbu is offline
Old 02-03-2023, 10:27 AM
  #125
I might give it a go, I'm not racing until next Friday now.
The electrics shouldn't be a problem as the layout will still be almost identical just on the other side and the motor at the rear. Only issue might be if your power leads arent long enough
hipwell is offline
Old 02-03-2023, 10:59 AM
  #126
zuqbu's Avatar
I couldn’t help myself, I am converting it right now, and will try to be on track tomorrow
zuqbu is offline
Old 02-04-2023, 02:40 PM
  #127
let me know how you get on, I'm considering it.
hipwell is offline
Old 02-05-2023, 02:36 AM
  #128
zuqbu's Avatar
I tried the rear motor layout for the first time yesterday, and if you're trying to eliminate traction rolling with it – don't Same issue. The only thing that solved it for me is applying glue not only on the tire walls but also on the tread (1–2 mm). The car drives equally fast though, and the rear motor layout is a bit lighter (~15g).
Nicadrauspro4 likes this.
zuqbu is offline
Old 02-05-2023, 05:46 AM
  #129
Brill, sounds good then.
Did it remove any of the steering at all?
Why is it lighter? Because theirs only 1 prop shaft?
hipwell is offline
Old 02-06-2023, 03:37 AM
  #130
zuqbu's Avatar
No, I didn't notice any removal of steering. I also played around with droop settings but that was making things worse.
It is lighter because the single prop shaft equals less parts, and the spur gear is more or less directly connected to the rear input shaft (which is smaller as well) removing the need for a center cup (these are out of steel and comparatively heavy).
zuqbu is offline
Old 02-08-2023, 07:05 AM
  #131
Isaac's Avatar
Nice wiring. Looking at it (looks good) I am thinking an aluminum chassis is needed at minimum if running on carpet. Also wondering about the width of wheelbase. Raise the roll center under the suspension as well?
Isaac is offline
Old 02-08-2023, 08:12 AM
  #132
Core Creations's Avatar
Trader Rating: 110 (100%+)
I originally built my EVO 8 up in rear motor configuration, but the torsional flex was extreme (close to my TA08). So I built it with the front motor configuration and that took away a pretty decent amount of that flex. I agree it still needs an aluminum chassis for carpet, but it's still decent even with the flex.
zleader_99 and V8 Rumble like this.
Core Creations is offline
Old 02-08-2023, 02:49 PM
  #133
I've just been checking the setup on my evo compared to on my 419xr and the evo stock setup has got crazy amounts of ackerman.
I'm going to adjust this by a mm or so and see if it tames the steering down.
hipwell is offline
Old 02-18-2023, 12:13 PM
  #134
Had a good run last night, added the front roll bar from my 419 which was thicker, I think 1.3mm, car didn't roll once. Xray 2.6 on the rear and 2.5 -2.8 on the front. Car felt amazing, untill the final and then the internal gears in the diff stripped
Got some metal gears on order now.
zleader_99 and zuqbu like this.
hipwell is offline
Old 03-02-2023, 12:02 PM
  #135
How tight are people doing the nuts on the top deck at the bulkhead end?
Should the top decks be able to fall under their own weight to avoid tweak?
Or be mega tight?
Ive noticed even after a slight knock im having to loosen the top decks on the spur gear mount to relief tweak, but think if the decks alwere a tad looser on the ends, it wouldnt tweak it, but would cause more front to rear flex, and its got plenty of that
hipwell is offline
