Like Tree115Likes
Tamiya TB Evo 8
Old 11-22-2022, 05:55 AM
  #76
IAmGreatDane's Avatar
Originally Posted by zuqbu View Post
Progress after parts bag B:
The one-piece aluminum diff housings are a work of art. Machined with precision and stunning quality, and so satisfying to assemble. I don’t want to know what they will cost as spares
Congrats on your purchase. Looks fantastic. I have a question: What is the overall width of the chassis? Thanks c'',)
IAmGreatDane is offline
Old 11-22-2022, 12:08 PM
  #77
zuqbu's Avatar
Originally Posted by Eotz View Post
Very nice car. Just a question. How much does that car weigh? Those bulkheads looks massive.
Tamiya states 186mm track width. Or do you mean the lower chassis plate? That would be 88mm.
zuqbu is offline
Old 11-22-2022, 03:07 PM
  #78
minidriver's Avatar
Wow- if that is reading 679g that’s 40 grams heavier than the evo7 I have as a beautiful shelf queen! Was too heavy! Would be interested in a review In performance against something like a TRF420. Only chance of being near class weight is with a shorty pack.
or is the weight 619 g on that scale above?
minidriver is offline
Old 11-22-2022, 03:27 PM
  #79
zuqbu's Avatar
It’s 619 g – sorry for the picture quality.
Eotz likes this.
zuqbu is offline
Old 11-22-2022, 10:29 PM
  #80
The chassisplate. Sorry, I wasn't specific in my request. Thanks. Much appreciated.
Old 11-23-2022, 02:00 AM
  #81
zuqbu's Avatar
Quick note: After assembling I noticed some binding in the rear gearbox, I added a 0,1mm shim in step 6 as pictured here – that eliminated some play that could push the bevel gear into the differential.
Another potential source for binding are the polycarbonate dust covers – they can touch the diff housing in the rear. I made a small cutout on that side.
zuqbu is offline
Old 11-23-2022, 03:11 PM
  #82
Casey's Avatar
minidriver we need you to come out to the TCS race in Maryland in Feb.
minidriver likes this.
Casey is offline
Old 11-23-2022, 10:46 PM
  #83
619g is still 70g heavier than most other shaftdrive cars...Lots of heavy aluminum parts on the tb evo8...
bertrandsv87 is offline
Old 11-26-2022, 09:32 PM
  #84
rc_square24's Avatar
Nice looking chassis! Is there any loss of longitudinal rigidity around the spur gear? I'm asking as I've noticed that the supports that are on either side of the spur gear is not bridged by a top cap (like on the Evo7) and it seems that it's either the chassis plate or the spur shaft to resist longitudinal flex around that zone. Although the Evo7 also has this discontinuity lengthwise, they're located close to gearbox area where the effects of bending are less significant.
rc_square24 is offline
Old 11-28-2022, 02:53 AM
  #85
Just finished building mine, and yes there is loads of flex around that area where the spur gear is.
Disappointing that they didn't bridge it with a top cap like on the evo 7. I wonder if the part from the evo 7 would fit if you get get hold of one.
I hope tamiya releases it as a hop up option, my biggest fear is the chassis splitting there in a collision.
hipwell is offline
Old 11-28-2022, 05:11 AM
  #86
The one from the Evo7 will likely not fit as you would then lose the mounting points for the Evo8 top decks, moreover the Evo7 top cap uses three screws and the forth hole being a keyed opening.
Just by photos, the chassis (esp. being carbon) should be okay in a hard frontal impact, and most likely the spur shaft and bearings would take the hit.
They could have made a bridged top cap with offset mounting points and slightly shorter top decks. Only time will tell if it's an issue or not.
As far is as I know Tamiya has stopped the strategy of offering hopups for Evo specific cars since as far back as the Evo6, likely due to the much smaller production quantities compared to their other RC lineup. A run of MS version of kits is more likely than hopups.
Old 11-29-2022, 08:50 AM
  #87
Khoff77's Avatar
Did you get one of these?
Khoff77 is offline
Old 11-29-2022, 10:24 AM
  #88
Anybody used it yet? I will be on Friday, low/medium grip carpet, stock setup.
The stock front end seems quote narrow, it suggests the e block with the inserts inwards 1 notch, which i assume is what on the old system would be a D block.
I've always found F to be the best on my 419xr.
hipwell is offline
Old 11-30-2022, 08:41 PM
  #89
gene465's Avatar
Trader Rating: 51 (100%+)
Can the car be set up so the battery be mounted on either side? Anyone know?
gene465 is offline
Old 12-01-2022, 04:00 PM
  #90
I think so.....Checkout the manual...
