Tamiya TB Evo 8
#31
#32
Posted the full product description on the TB Evo 8 now, containing all details of the kit:
https://kentech.wordpress.com/2022/0...o-8-full-info/
#33
#34
I think this chassis is good to run if converted to FF configuration.
Unfortunately nowadays the International race rules of FF disallowed to run "self-made" chassis, and the other problem is the gear ratio is limited until 5.0 or 4.5 fdr, the weak point of shaft cars of they would have disadvantage in case they run same gear ration as belt drive cars.
#35
Torque steer
Considering the awesomatix a700 ffg/rfg and xpress at1 ffg/rfg systems to counter torque steer. Will the tb evo 8 have issues with torque steer?
For that matter, why is torque steer not an issue with 4wd buggies? How is it an issue only for onroad shaft drive cars?
#37
Tamiya TB Evo 8
Spoiler 🚨
#39
They do torque steer, it's just not easily perceptible as the surface is moving about underneath them. Try a 4wd shafty on high grip astro with a mod motor, it'll torque steer.
#45
But I think there was a reason behind the slower gear ratio - reducing torque transmitted through the shaft to reduce twisting of the chassis.
