Like Tree205Likes
Tamiya TB Evo 8
Old 08-02-2023, 06:08 PM
  #256
Originally Posted by hotdognobun
Both my front blades gave out during a shakedown. I guess after 13 packs on 17.5 it was bound to happen. Thanks for the link it actually got me up and running for tomorrow. Have you had the blades go out in the rear yet?
From my calculations, I have ran over 200 packs (21.5 though) and I am still on the original set of rear out drive / blades. Cannot say the same for the front. At the same time I have broken 3 front arms and gone through 6 packs of the uprights. I am now using the 420 C parts upright (51638), it seems to be made out of a stiffer more brittle plastic. The bearing seems to have a better fit too.
200sxr is offline
Old 08-03-2023, 11:18 AM
  #257
hotdognobun's Avatar
Trader Rating: 32 (100%+)
I will definitely give those a try have that carbon reinforced color to them. Love Tamiya compatibility from other kits
hotdognobun is offline
Old 08-03-2023, 11:20 AM
  #258
Originally Posted by hipwell
25.5? That's unheard of over here, must be slow as hell?
For 13.5 I run 5.0, and 17.5 run 4.6, sorry cant help with 25.5.
I think 25t is the VTA class which look pretty quick but the tires they use makes the car so squirrelly lol. Let me ask what gearing/FD they are running
Old 08-06-2023, 03:36 AM
  #259
Originally Posted by Bonezero
What gearing are sweet spot for 25.5TC?
I run with 21.5T here in Aus. The FDR we run with is between 3.4-3.8 pending on motor and track. So I guess with the 25.5T would be lower. I use a 59 teeth spur.
200sxr is offline
Old 08-06-2023, 12:49 PM
  #260
I thought the kit evo ones were the same as the 420 ones? It's the same part number in the evo 8 manual. Mine have been pretty reliable, managed to break one of the arms which screw onto the rear uprights so replaced it with a carbon arm from a 420 and its been fine since.
hipwell is offline
Old 08-08-2023, 02:43 PM
  #261
zuqbu's Avatar
All this talk about wearing out blades made me double check my car tonight, and I have no signs of wear or tear on any of them – neither front nor rear. Also no sign of any play between the joints. Is it the torque of a 21.5 motor that is destroying them or what? My car is well beyond 100 runs on a 17,5T motor with a FDR of 6.5. I usually stock up on a lot of parts for any runner but I haven't had to replace anything yet in the TB-EVO 8 yet (luckily).
h2e and BuggyFan21 like this.
zuqbu is offline
Old 08-10-2023, 01:54 AM
  #262
Originally Posted by zuqbu
All this talk about wearing out blades made me double check my car tonight, and I have no signs of wear or tear on any of them Ė neither front nor rear. Also no sign of any play between the joints. Is it the torque of a 21.5 motor that is destroying them or what? My car is well beyond 100 runs on a 17,5T motor with a FDR of 6.5. I usually stock up on a lot of parts for any runner but I haven't had to replace anything yet in the TB-EVO 8 yet (luckily).
Tamiya been making shaft cars forever. I believe the complaining about worn blades and gears are just rookies with shaft drive cars. And most likely built the cars wrong. Canít have slop. And you canít build a Tamiya shaft car with kit shimming. You have to take extra care in shimming every part of the driveline to be free without any slop. Or youíll break gears.
Raman, gwhiz, Eotz and 2 others like this.
Juan Aveytia is offline
Old 08-10-2023, 03:28 PM
  #263
Originally Posted by Juan Aveytia
Tamiya been making shaft cars forever. I believe the fee that are complaining about worn blades and gears are just rookies with shaft drive cars. And most likely built the cars wrong. Canít have slop. And you canít build a Tamiya shaft car with kit shimming. You have to take extra care in shimming every part of the driveline to be free without any slop. Or your break gears.
The blades we are talking about are nothing to do with it been a shaft car, they also use the same blades on the 420 which also had similar issues and tamiya revised the new the LF dogbones with longer pins to fit the blades better when the 420x was released.
your right though, kit shimming on the crown and bevel gears is useless and needs correcting before you run
hipwell is offline
Old 08-10-2023, 04:28 PM
  #264
Guess Tamiya needs to put in more R&D in their shaft cars since my base build was what their instruction recommended.
Old 08-11-2023, 07:39 AM
  #265
Iím a long time Tamiya racer. Never had problems with the blades youíre talking about. Iíve seen people narrow the car too much and the blades get too tight and jammed in the diff. I wonder if thatís what is happening to some of you. And the same goes for making the car too wide. The blades can pop out
Old 08-11-2023, 07:44 AM
  #266
The manuals are close. But not even close to perfect. Maybe if all the gears were made of metal. But theyíre plastic. Iíve owned a few Tamiya shaft cars Evo2, evo3, evo4,evo5, tb02,tb04
Old 08-11-2023, 02:20 PM
  #267
Those were great kits you had I always wanted the Evo 3 Surikarn edition.
Old 08-25-2023, 04:40 AM
  #268
I'll be running 17.5 next week when I get back from holiday. Bought a surpass v6. Got a feeling this evo will be a bit of a monster in 17.5 with the drivetrain being so free.
hipwell is offline
Old 08-25-2023, 02:29 PM
  #269
Been running 17.5 with 4.0 to 4.5 FD. Chassis handles it so well
Old 08-27-2023, 12:13 PM
  #270
Yeh im curious as to what fdr to start with. I was going to go for 4.6, but feel that the evo with such a free drivetraine might actually be better with like 4.4
I've ordered spur gears to get me from 4.4 to 4.8 so I can have a play. Might start at 4.4 and monitor temps from there
Most guys at our club with xrays, mugens etc seem to be running around 4.5, but i recon the evo is more efficient so might get away with going lower
hipwell is offline
