Tamiya TB Evo 8
#196
Any one running on Low/Med grip asphalt? I took it out yesterday with the kit setup in VTA and it was bad no rear traction on power. Any suggestions on what direction to go.
#197
what do you call rear traction?
#198
I call rear traction the traction produced by my rear wheels. Are you asking to answer the question cause I am sure you can deduce what I meant by what I wrote or just to make a comment.
#199
Make sure your running 3 degrees rear toe in anything less on low grip is undrivable. I run 2.5 degrees on the blocks and then top it up to 3 with the tie rods
#200
Thank you. I’m running 6 upfront and 5.2 rear for droop. I will increase my toe as I was running 2.5.
#201
I would possibly go to 5.5 on the front droop too, itl allow a bit more weight transfer to the rear wheels on power.
Actually scrap that, might make it worse actually cos if it's on power, it's probably cos you've got too much rear end and not enough front.
Do the toe first, makes a massive difference
#202
I also found running more droop front and rear decreased the tendency for power oversteering.
A couple of items for car setup. Does anyone use bearings oppose to the bushes with the rear diff?
With the shocks, I have found the box orings to be very leaky. I have replaced the original oring with some thicker orings with 3mm ID in one kit and placed a 0.5mm shims on the original orings with the second evo 8 that I have. Both sets stopped leaking and had minimal change with the damping action.
#203
The stock shock o rings are useless, i replaced them with axon or-so-001, no leaks now.
I did try using a 0.5mm shim with the tamiya o ring as you mentioned, it did stop the leaks to be fair, but did cause a little bit of extra drag so went for the axon ones.
#205
2nd week running now with the new setup, not a single grip roll and no glue on the tyres
Low roll centres is the way forward
