Like Tree205Likes
Tamiya TB Evo 8
Old 03-31-2023, 03:40 AM
  #166
Originally Posted by 200sxr
I found a new kit here in Australia, and it is now on the way to me. I raced on an outdoor track for the first time over the weekend. I wanted to try more front, so I widen the front track by 0.75mm using wheel spacers and I was surprised by how much more steering I got. To a degree, it got a bit too tail happy. I hit a barrier when I was trying to correct a snap oversteer and broke a front upright.
Much to improve!
Oops. I run my front end in the F block setting, which is 2 notches out from the kit D setting. I find it tames the front down a little. My car has got so much steering whatever changes i make so ive just had to turn down the dual rates to about 19degrees on max lock.
also, ive put some titanium steering arms on now as for some reason I kept bending the aluminium ones even after a slight knock. Hopefully the titanium will have sorted it
hipwell is offline
Old 04-07-2023, 01:46 PM
  #167
Does anyone know the part number for the optional rear body mount stays?
JUNI is offline
Old 04-08-2023, 06:27 AM
  #168
https://sakaguchinetshop.com/product...oducts_id=6655
Mine came with a set in the kit though
hipwell is offline
Old 04-08-2023, 09:24 AM
  #169
Thank you
JUNI is offline
Old 04-12-2023, 05:27 AM
  #170
Has anyone seen the clear gear cover anywhere? The one on the rear bulkhead broke where the tabs are. Otherwise the car is going well and still learning about on road racing.
200sxr is offline
Old 04-12-2023, 01:10 PM
  #171
hotdognobun's Avatar
Trader Rating: 32 (100%+)
https://www.tamiyausa.com/shop/7-dig...r-cover-42383/
I wish they would release a smoked or translucent blue version line the EVO IV days
hotdognobun is offline
Old 04-13-2023, 04:53 AM
  #172
Mine is flying now, i love seeing peoples faces when they see its a tamiya shafty that's beating them.
the kit setup is terrible though, it's took alot of tweaking to get it there.
hipwell is offline
Old 04-13-2023, 01:09 PM
  #173
I just picked one up 2nd hand and the last owner had it setup pretty good for high grip surfaces. I have a parking lot race this Sunday with med/low surface so hopefully I can get used to this chassis during practice cause iím so used to belt cars
Old 04-15-2023, 08:03 AM
  #174
I back to back my new EVO 8 against my first one to make sure the handling is similar. One thing I have noticed is that the old one was heaps louder. Upon closer inspection the rear drive under the cover was full tyre dust. The crown and pinion was packed full of it. I think majority of it came from the 2 m3 holes in the bulkhead where they are used for the steering link in the front. I blanked them off with 2 m3 screws. Also put some small foam triangles on the top edge of the bearing to seal off that area just in case.
hotdognobun likes this.
200sxr is offline
Old 04-18-2023, 12:38 PM
  #175
The biggest issue I'm finding with this car is that after the slightest knock on the front end the chassis tweaks around the spur gear mount and I have to release it with the 2 top deck screws. I really wish they'd used a solid brace like on the evo 7
hipwell is offline
Old 04-19-2023, 01:37 AM
  #176
zuqbu's Avatar
I have experienced the same. Honest question because the tweak seems very slight, can you feel a difference in the car's behaviour? Because I don't but I am also not the best driver
zuqbu is offline
Old 04-19-2023, 06:17 AM
  #177
Hmm, difficult to say, the car never feels right after a knock mid race, but I think alot of that is mental.
But, I have also found that it's took out the bearings on a couple of occasions on the centre shaft, assuming because they take the hit when the chassis flexes and tweaks in that section.
I was considering trying the rear motor option, I feel like it will be less prone to tweak at the rear, and if it does tweak at the rear it's less likely to Impact on the steering.
hipwell is offline
Old 04-19-2023, 09:17 AM
  #178
I see what you mean, my centre bearings were rough also and I presume is from the knock even when I have a brace between the 2 top desks. Regarding if the tweak around the motor mount affects the handling. The engineering tells me it does not as the tweak should be even on both side due to the way the top desks are linked but I have also experienced a slight change in steering after a hit and it seems to fix itself after releasing the tweak. Strange.
200sxr is offline
Old 04-19-2023, 10:56 PM
  #179
Default Servo
How is everyone running the servo cable with the central spur setup? My spur already ate a chunk out of the cable
Old 04-21-2023, 10:13 AM
  #180
When you say central spur setup do you mean motor on the front left?
If so I just run the servo cable under the motor, it goes nowhere near the spur gear as my servo sits in front of the motor and the cable exits on the left and then i just tuck it under the motor with a bit of douvle sided tape
hipwell is offline
