Which pre-glued tires should be chosen on low grip carpet? >
Like Tree9Likes
Old 07-16-2022, 11:30 PM
mac853's Avatar
Default Which pre-glued tires should be chosen on low grip carpet?
Hi, I want to know of following different pre-glued combo tires below, which of them should be chosen on low grip carpet in case the rules is BYORT?
You can even add or put in comment in case you have another better choice of pre-glued combos or even you would have "self-made" combo(tire+insert+wheel)?
Best regards:
Volante V5 Pre-Glued 24R-CP Indoor Carpet Rubber Tire
VOLANTE V5 1/10 TC 28CP INDOOR CARPET RUBBER TIRE PREGLUED
Yokomo Yatabe Arena 28Degree Pre-Mount Y.A. Control Tires
Hudy Pre-Glued Carpet Tires C3-28
HUDY 1/10 Touring Carpet Tires C1
Rush PreGlued 1:10 Touring Car Carpet Tyres 30CPM
Sweep SR-CX28PRO Pre-glued carpet tires
Sweep SR-CP32PRO Pre-glued Carpet tires
Sweep SQT-28PGL Carpet tires
Sweep SQT-32PGL Carpet tires
mac853 is offline
Old 07-17-2022, 06:18 AM
RobS's Avatar
Sorex 28's
RobS is offline
Old 07-17-2022, 06:56 AM
mac853's Avatar
Originally Posted by RobS
Sorex 28's
But what kind of insert to match Sorex tires?
Yokomo 039m?
mac853 is offline
Old 07-17-2022, 07:29 AM
rc_square24's Avatar
Do you know what kind of carpet you are running on (CRC Ozite / CRC Black / ETS)? And by BYORT rules you mean Bring Your Own Rubber Tires?
rc_square24 is offline
Old 07-17-2022, 07:44 AM
mac853's Avatar
Yes, BYORT means not handout or free choice tires.
None of these carpet.
In fact I verified many place in Asia use "Indigenous" carpet, so is not usual.
BTW, I didn't know there's 2 kinds of CRC carpets.
For curiosity, those used in Indoor Champs of Cleveland, Snowbird and Tsukuba park of Japan are not Black one?
mac853 is offline
Old 07-17-2022, 08:06 AM
robk's Avatar
Trader Rating: 22 (100%+)
Cleveland and Snowbirds are black Crc. No idea on Japan.
robk is offline
Old 07-17-2022, 08:22 AM
Tsukuba RC Park (the new name of Yatabe Arena) is using CRC Black, since 2018 I think.
My pick for low traction would be:
Old 07-17-2022, 08:41 AM
mac853's Avatar
PGLs?
OK, thank you?
mac853 is offline
Old 07-17-2022, 10:37 AM
SteveM's Avatar
Trader Rating: 165 (100%+)
Sorex and depending on what you mean by 'low grip' try 20R, 24R or 28R compounds.
skater-deez1 likes this.
SteveM is offline
Old 07-17-2022, 11:00 AM
mac853's Avatar
But is Yokomo 039M insert that you are using, right?
mac853 is offline
Old 07-17-2022, 11:15 AM
SteveM's Avatar
You asked about 'pre-glued' and the ones I used were sold by Schumacher and use the black insert. We normally ran Sorex 28R Premount w/ Black Insert + Revlite Wheel. Part number SCHXG28RK
mac853 and gigaplex like this.
SteveM is offline
Old 07-17-2022, 11:26 AM
mac853's Avatar
Is good to take note, but I could see it it discontinued, anyway thanks!
But what kind of traction compound use?
Hudy, MR33 or LRP one?
mac853 is offline
Old 07-17-2022, 11:33 AM
SteveM's Avatar
We were limited to use no-odour traction compound made by SXT
SteveM is offline
Old 07-17-2022, 11:37 AM
mac853's Avatar
But which of 3.0, all 3 bottles?
mac853 is offline
Old 07-17-2022, 11:44 AM
SteveM's Avatar
I believe we used SXT00030
mac853 likes this.
SteveM is offline
