Like Tree35Likes
ARC A10
Old 07-15-2022, 04:32 PM
  #46
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by TryHard
I look at it another way, as with double turn buckles it's no heavier, and you can get exactly the same castor/camber side to side. Just ask the mugen guys about how unless you build it it just right, castor will be off left to right... I know what option I'd take.
the same goes when settings it on the R12.1 and now the A10.
STLNLST is offline
Old 07-18-2022, 08:33 AM
  #47
How can I set for front caster and rear caster?
This is my first double A upper arm car
does anyone have video?Thanks
TonyPan is offline
Old 07-18-2022, 08:45 AM
  #48
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
it comes with a caster gauge and you adjust it by the 2 turn buckles in each arm
the car uses the same upper links as the AMX
over gear and 1spunspur like this.
Marcos.J is offline
Old 07-18-2022, 11:47 AM
  #49
Thanks!
but when I adjust upper links to adjust caster ,isn't it change camber value?
TonyPan is offline
Old 07-18-2022, 11:51 AM
  #50
Turning both turnbuckles the same direction changes camber. Turning both turnbuckles the opposite direction changes caster.
malkiy is offline
Old 07-18-2022, 05:57 PM
  #51
Airwave's Avatar
Thanks!
Yes it will. It is the problem with double arms like that. But as we don't change caster very often...
Airwave is offline
Old 07-18-2022, 07:24 PM
  #52
Trader Rating: 16 (100%+)
Thanks!
If you use the same amount of turns in the opposite directions, it will not change camber by very much, if at all. So if you want to increase caster, shorten the back link by 1/4 turn and lengthen the front link by 1/4 turn and then the camber doesn't change.
glennhl is offline
Old 07-18-2022, 07:59 PM
  #53
tak4's Avatar
This also adds tension to the arm and causes binding....
tak4 is offline
Old 07-18-2022, 08:59 PM
  #54
gigaplex's Avatar
Only on cars that use conventional C hubs in addition to dual links. This is not one of those cars.
h2e likes this.
gigaplex is offline
Old 07-18-2022, 09:01 PM
  #55
h2e
h2e's Avatar
Not really. The upper A arms should always be able to run without binding, as the two links have adjustable angle between each other.
For all fixed upper link triangles, it's more difficult to achieve (MTC2, Destiny 3.0, Sakura Cero etc).
h2e is offline
Old 07-23-2022, 08:40 PM
  #56
5th wheel's Avatar
Is the A10 a 1.9 or 2.0 fdr
5th wheel is offline
Old 07-23-2022, 09:03 PM
  #57
gigaplex's Avatar
1.9. The manual is online.
gigaplex is offline
Old 07-24-2022, 03:39 AM
  #58
J SiN's Avatar
Yep 1.9 it's the same drive train as the R12.1
gigaplex likes this.
J SiN is offline
Old 07-25-2022, 11:29 AM
  #59
5th wheel's Avatar
ok thank you..thinking about getting one
Old 08-01-2022, 03:55 AM
  #60
J SiN's Avatar
Here is a review I did on the new A10 has heaps of pics.
5th wheel and mr.rev like this.
J SiN is offline
