GEAR RATIO'S 540 GETTING THE MOST
As a new RC junky i have started in the 540 class , i currently have a venom pro chassis with a sports tuned 540. What would be the fastest gear ratio for a tight track??? In this class with such close racing any edge obtained would be an advantage
If it's a Tamiya Mabuchi Sport tuned try around 5.7 or there abouts.
Gear the motor as high as you can until it smokes, then take 1 tooth off the pinion. This is then the correct ratio you should have run before you cooked the motor. If you are running 540 class you cannot legally run the sport tuned motor. Johnson 540 is the only legal motor
hmmm not really true. depends on track. some tracks i do 38mm some up to 44mm rollout. i go faster on 38mm than on 44mm on a tight track that requires lots of punch. cheers
Green Machine - 540 gearing and breaking them in is a closely guarded secret
Only few knows...... right ?
