Old 04-13-2006, 09:09 PM   #1
rag
Default two esc issues
i baught a new trinity clash and a new mini quake for $50 about two weeks ago.
here is what i need:
-reccomendations for a reversable mini esc
-a diagnosis. the mini quake turns on and runs fine for about two/three minutes, but after that it stop responding completely, i turn the car off then on and it twitches for a split second then resume its unresponsive state.
so if worse comes to worse i will be purchasing two mini esc's
if its any help both esc's are LM-406FB models
rag is offline   Reply With Quote
Old 04-14-2006, 12:34 AM   #2
Superkarter's Avatar
If u leave it for a while does it start working again. If so it may be getting to hot.
Superkarter is offline   Reply With Quote
Old 04-14-2006, 01:01 AM   #3
brownpants's Avatar
Sounds like you are over working the esc and its getting too hot as Superkarter suggested.
I had this trouble with a cheap esc I brought. Think it would be worth getting a better one.
Darren
brownpants is offline   Reply With Quote
Old 04-14-2006, 01:35 AM   #4
Nicadrauspro4's Avatar
Like Superkarter & brownpants said, you're ESC might be over heating. Try this:
Replace all the bettery and motor wires to lower gauge. If the stock gauge is 18, then replace it with 14. This way the thicker wires will help absorb heat coming from to the ESC. Also try installing a capacitor and heat sink on your ESC.
Your ESC should work better after that procedure.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 04-15-2006, 06:49 AM   #5
rag
the esc on the clash basically overheats and smokes. but the temperature on the mini quake's esc does not pass room temperature.
im still looking for reccomendations for a pair of mini esc's
thanks
Old 04-15-2006, 07:20 AM   #6
thanks
I recommend LRP's Quantum 2 Micro. It is a good choice.
XXX-S issues rcketch Electric On-Road 4 07-20-2008 06:27 PM
CX2 Issues 140ce RC Flight 4 01-21-2008 12:12 AM
new and have some issues.... im faster Nitro On-Road 4 03-01-2007 05:31 PM
TRX 2.5 issues C_J_GO Monster Trucks 0 10-18-2006 04:00 PM
Old issues? [email protected] Electric On-Road 2 07-27-2006 10:05 PM
